inlet manifolds?
5 posts • Page 1 of 1
inlet manifolds?
whats the difference between the 130 bhp inlet and the 105 bhp one?
- 2.0zetec
Re: inlet manifolds?
the 130ps inlet has bigger ports so flows better than the 105ps item
- hb69
- Your car: Fiesta 1.1 LX
so is that all the way through manifold and is there any effective way of freeing up the flow (enlarging the ports?) to a similar spec?
- 2.0zetec
there is no way you could port the entire manifold due to the curves etc.
also the ports should all be equal to ensure even air to each cylinder which simply could not be done by porting a manifold as you are thinking.
- xrsi
- XR(ustyAtTheMo)SI
The 130 (HO) version from the outside is obviously a larger casting so even if you could port the SO one out by the time you had finished there would either be holes in it or the walls would be a s thick as tracing paper.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
