Intercooler choice
5 posts • Page 1 of 1
Intercooler choice
As some of you may know i'm trying to build a budget ZT
Been wondering about choice of intercooler.
Would it be ok to use the FRST Rad an intercooler? bearing in mind i'm only looking at running ~10psi.
been offered a 4wd saff cossie one but that means modifying the lower front bumper to get it on.
any ideas?
JJ
any ideas?
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
He's asking if he can use the FRST radiator and intercooler setup on his car Chris I'd say you could get by with the FRST intercooler TBH, if you were going no higher than 10psi, but would undoubtedly be better of with the 4x4 cooler.
cheers James, yes i was thinking of using FRST Rad and intercooler. only want to run 10psi so surely it should cope fine with that
Chris, was thinking of putting the cossie one in a similar place, but as it's an Si, it would mean chopping the rear of the bumper, and the lower front panel
JJ
JJ
- jdfiesta
- Your car: V70 T5
