interior help
3 posts • Page 1 of 1
im have si front and rear seats in my standard mk3. only problem is how do i get the rear upper bench in??? i got the fronts in and the lower bench was a piece o pich but the upper comes as two sections rather than the one. Will i have to drill the upholstry on or what? any help guys?
john
john
- Johnny_16v
I would presume that the Si has split seats, so why dont you take the hole units.
You will need a "large" (not sure what size) torx head and remove the 4 retaining bolts.
Hope that helps m8tee!
- fiestastyle
