iPod Wireing
iPod Wireing
Postby JohnBoy_DIY on Fri Feb 09, 2007 12:00 am
Just Wondering i cant be assed to change my head unit again but i was just wondeering if it would be posable to run my iPod through the car speakers withut goin into the headunit??
JohnBoy_DIY
Your car: CAR
Postby richard_p88 on Fri Feb 09, 2007 12:19 am
Yes it's possible.
You'll need a two or four channel channel amp depending on how many speakers you want to use though and a switch or something to turn the amp on and off using the remote wire.
From there just connect your ipod to the amplifier using an RCA lead with the appropriate connection for the ipod.
But there you have it, a rough guide on how to have tunes without a head unit :D
richard_p88
Postby ukgaz on Fri Feb 09, 2007 10:35 am
theres also adapters from company called connect2 for ipod adapters
ukgaz
Postby dontpannic on Fri Feb 09, 2007 11:22 am
What I've got is an FM transmitter (you can get them for a tenner from your local computer fair), and my ipod cable, both running into a double cigarette lighter socket. I have an extension lead on the FM transmitter and the ipod is connected to the dock. It's perfect sound quality and even charges your ipod!
CIG LIGHTER ----------- USB CONVERTER----------IPOD CABLE-------DOCK
____________\----------FM TRANSMITTER-----AUDIO EXTENSION----DOCK
All hidden away behind the glove box, so all you see is the dock, which I hide in the glove box when I'm not using it. I'm going to cut a small flap into the dash so I can leave the dock there all the time and just sit the ipod into the top of the dash. Works perfect. Plus if you're in convoy, other people can tune into the same frequency and share your tunes!!
EDIT: Plus only costs £20 (for the transmitter and ipod dock)
Postby JohnBoy_DIY on Sat Feb 10, 2007 1:11 am
I have a transmitter but i cant find a empty station so i always get 2 signals coming in. therefor i am after a way of doingit withut the headunit...
tho i think its abit over the top 4 me at the moment maby my next install.
JohnBoy_DIY
Your car: CAR
