is it true, with.....
5 posts • Page 1 of 1
g-max kits u have to trim ur bump stops by 20mm????
That is what i have heard from someone on here who has got a gmax suspension kit!
I have had mine fitted for a while and was never told to have it trimmed by 20mm, so i wanted to check if anyone else had had it done!
Thanks - Raj
Thanks - Raj
- rajaboyuk
id agree when i had my old 1.4 ghia dropped 35 on my gmax set up the intructions clearly said they had to be cut down, you will get a well rough ride over mid to large bumps otherwise, as u hita bump the spring and damper will be absorbing the bump and moving upwards and will suddenly gammon slipper the bottom of the untrimmed bump stop. i trimmed mine down a bit more than 20mm as my cd player was skipping like mad, was much better afterwards.
Rich
Rich
SPEED KILLS,
BUT GETS YOU THERE FASTER
- MustangSally
