iscv problem
iscv problem
Postby rich1987 on Sat Sep 14, 2013 9:08 pm
right not had my frst running for a few months while I sort out the fuelling system, went to start it today and was idleing high and the revs would drop really slow so unplugged the iscv and car and the revs drop and car acts normal so thought I would clean it out following jays guide on here but decided to test the solenoid first, now when I turn the ignition on I can feel the solenoid click but the bit in it doesn't move inwards does this mean its f**ked? or is it something else? cheers
rich1987
Your car: fiesta rs turbo (zvh)
Re: iscv problem
Postby FRSJON on Sat Sep 14, 2013 9:45 pm
they can be problematic so if you have a spare or can find one, try another.. or you have a air leak somewhere
FRSJON
Re: iscv problem
Postby rich1987 on Sat Sep 14, 2013 10:44 pm
Yeah do need to check for air leeks but i thought the solenoid should move when the ignition is on?
rich1987
Re: iscv problem
Postby jayrs on Mon Sep 16, 2013 6:17 pm
I would say check ft air leaks also.
Also disconnect the battery for a few mins and try again, this should reset the ecu, and it should hunt while it sets its base idle again.
Could also be a TPS problem?
Re: iscv problem
Postby rich1987 on Sat Sep 21, 2013 6:35 pm
Right i found acouple of leaks which are now sorted, disconnected the battery and tried again, it now idles just about right but it you rev it it takes again for revs to drop down and after that it revs up and down on its own, if i unplug the iscv its fine does this mean the iscv is nackered? Cheers guys
rich1987
Re: iscv problem
Postby jayrs on Sun Sep 22, 2013 1:14 am
Sure there's no more leaks on the inlet?
Could be a potential TPS fault??
I have come across a could of fiestas with the iscv unplugged before and the owners drove them around like it...
Dunno if I said before, but wd40 in the sensor plugs to rid any dry joints is a good move, even if it doesn't solve the problem it can be ruled out
Re: iscv problem
Postby rich1987 on Sun Sep 22, 2013 9:36 am
Ive sprayed brake cleaner eveeywhere covered the inlet manifold and it didnt chaned anything, i'll give it a go im gonna give the iscv realy goid clean incase its sticking, i am tempted to just leave it unpluged but it'll bug me not knowing whats wrong bit ocd hahaha cheers jay
rich1987
Re: iscv problem
Postby jayrs on Sun Sep 22, 2013 10:34 am
Laugh out loud na I'm the same mate, it's there to do a job so it's gotta be working.
Another thing it could be could be the temp sensor in the underside of the inlet, as this tell ths ecu what temp the coolant is at and thus the ecu controls what the ISCV does, so if the sensor is telling the ecu the engine is a temp it's not, it will hVe a effect on what the ISCV is doing and how the engine idles
Re: iscv problem
Postby rich1987 on Sun Sep 29, 2013 11:15 pm
Well i stripped it off cleaned every little bit so it was spotless and sprayed the connection with wd40 new gasket and work beautifuly now thank god starting to piss me off, got fuel problem now tho, car revs mint standing still but as soon as get turbo pressure around half a bar the car wont rev, im pretty sure fueling problem but not so simple as ive put all new fuel system in, alloy tank in boot with lift pump swirl pot bosh 044 pump teflon steel braided hose with regulator (set at 2.5) after the rail, smells like its over fueling me thinks gotta go to someone for a set up again
rich1987
Re: iscv problem
Postby jayrs on Mon Sep 30, 2013 7:25 am
I would advise having it set up again
