Issue With Helix Organic Clutch
Postby Amelia1987 on Wed Jul 22, 2015 6:55 pm
Can anyone help or advise what's gone wrong here please?
Fiesta turbo, standard gearbox.
Bought helix organic full clutch kit. Fitted and now the car creeps, crawls along with foot fully depressed on clutch pedal. Adjusted it up but soon looses adjustment. Had new cable fit too.
Was fine before hand. Clutch just started to slip.
Thank you
Amelia1987
Your car: Mondeo ST
Re: Issue With Helix Organic Clutch
Postby russ-RST on Thu Jul 23, 2015 10:42 am
Sounds like you need to adjust the cable at the ratchet in the footwell as the cable is too loose/tight not fully disengaging the clutch when the pedal is pressed
russ-RST
Your car: fiesta rs turbo
Postby Amelia1987 on Thu Jul 23, 2015 4:50 pm
Hi, thank you. Already done and fit a brand new cable.
ratchet is in good health and car was perfect with o/e clutch
Amelia1987
Your car: Mondeo ST
Postby snake on Mon Jul 27, 2015 11:57 pm
you can swap it out for a manual adjust one from an escort mk6/7 I think.
snake
Trainee Burger Flipper
Your car: ford
