ITB idle control
3 posts • Page 1 of 1
ITB idle control
just trying to clear up how the idle is controlled on ITB set-ups, im fitting gsx-r600 itbs btw. thanks, tom
- Si_2000
Re: ITB idle control
When i had my zetec running motorbike throttle bodies, i didnt use any idle controle. I set the cold start enrichments on the ecu etc and i just tweeked the idle screw as and when needed on the side of the itb's. Had it idleing slightly higher than normal, but never had any problems at all
- SamT
Some aftermarket ECU uses car use a idle control valve from a Cosworth or they run a cold start enrichment
- freak power
