ive got rear speakers?
Postby Norro on Tue May 30, 2006 6:38 pm
:-? the haynes manual says i have, but im not sure, and as i havent got the car yet, untill the 24th june, ive got no way of checking, so i thought id ask on here
1.1 hcs fiesta L
Norro
Norro
Postby Pez on Wed May 31, 2006 12:50 am
Yep you will have, in the parcel shelf supports. 4" diameter, horrible paper coned things, change em immediately :)
Pez
Postby Norro on Wed May 31, 2006 1:44 pm
simple as takeout/put in?
oooooo Beasty
Norro
Postby RS_Raz on Wed May 31, 2006 1:46 pm
very easy, 2 screws.... if you want to put aftermarket ones in you will need the plastic brackets from eBay.
I took them out and gave them to Paul, he was well chuffed :wink:
:Q
RS_Raz
Postby Joeys_Azura_1119!! on Wed May 31, 2006 10:56 pm
My 1.1 Hcs M reg didnt have any rears in it!!
Joeys_Azura_1119!!
Postby Tweek on Thu Jun 01, 2006 7:00 pm
I didn't think the base models had them? Just the fronts?
Your car: VW Golf GTD
Postby Joeys_Azura_1119!! on Fri Jun 02, 2006 11:13 pm
My ford head unit does have the 8 wires out the back fr fl rr rl each having a positive and negative but then there is a yellow ford plug taking it down to just the front channels!!
Bloody ford
Joeys_Azura_1119!!
Postby ~ John Reid ~ on Sat Jun 03, 2006 4:56 pm
if your changing the head unit, and your car has a little lever type thing ( under the steering coloum, by the choke) then you may hav to rewire your speakers, as car sterio headunits and speakers are meant to run at 4 - 8 Ohms, that directional lever, if moved with an aftermarket sterio on it made the speakers run at over 100 Ohms, blew the amp in the back of the sterio.
to rewire, just get yourself some speaker wire (quite thick), and run it direct from your speakers and wire it to the block that goes into the back of the sterio. to wire then, solder them then heatshrink them, or use wire connectors, quite easy.
put some 6x9's in ur rear shelf, if ya dnt wanna get some that fit where the old ones were that are more powerful, ( my standard speakers, when i took then out they fell apart :lol: )
~ John Reid ~
