Just..........
20 posts • Page 1 of 1
what sort?
wool, cotton? thick thin? white ?
all these must be concidered when mesuring.
also is it laid in a straight line or curved?
- thesylph005
TJ :How long is a piece of string?? In cm please!!
thesylph005 :what sort?
Didnt know you could get woolen string!!
From one end to the other end, what its its total distance!! (ie when laid in a straight line how far apart are the ends?
TJSEARCH
- TJ
A good question. In order to ascertain the answer to this question, we must perform a thought experiment. You can try and perform this experiment with an actual piece of string, but will probably cut your fingers.
Take a piece of string, and cut it in half. You now have two pieces of string, each half the length of the original. Now, cut one of the halves in half again. Cut one of the remainders into half, and this again, etc. The fact is, that no matter how many times you cut the string into half, you will never achieve a state where the length of the segment reaches zero.
So, eventually, you will have cut the string in half an infinite number of times, and hence you will have an infinite number of pieces of string which will all have a length above zero.
Obviously, any value above zero multiplied by infinity equals infinity, and hence through logical deduction we have proved that any piece of string is infinitely long.
I hope this clarifies the matter for you.
- JamieFRST
- Keep It Tidy
mixon :A good question. In order to ascertain the answer to this question, we must perform a thought experiment. You can try and perform this experiment with an actual piece of string, but will probably cut your fingers.
what if you aint got owt to cut it hou?
- InS@nE
that was a good website you found
R.I.P Rob...
"The Teenage Chicks Love The Car"
- TrekkieFRST
- Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
Capri :Mine's white cotton string with brown flecks in it, and it's been on the reeling road at 42cm.
pimsle! Quality mate! Absolutely quality!
TJ....he used a measuring tape.
- Choosey
- If only I had an RS1800....
- Your car: 2021 Jeep Wrangler
this long
- thesylph005
