k&n on fiesta si
5 posts • Page 1 of 1
k&n on fiesta si
i was thinking of puting a k&n on my fiesta si, but noticed that in the standard air filter there is a hole in the bottom of the casing, this goes down to the exhust manifold i believe. Surely if i remove the standard filter and replace it with a k&n it will connect only to the air flow sensor end and will just leave a hole down to the exhaust manifold. Has anyone got a k&n on an si that could help or does the k&n come with an extra pipe that connects to the bottom of the old filter, also how afective is the k&n filter at improving the car.
- james.alexander
my boyf put one on my si sunday so i don't know da ins and out but there was a black plastic flexible tube bout 2-3 inches wide that went from underneath the air box, curved round and pointed towards the front to suck in air.hope this helps, soz i can't be more specific!
- festamunster1
oh yeah and it'l only really make a difference with a full sys exhaust [ERRR] it's sucking in more air so needs to get rid of more gases
- festamunster1
sept its not that that limits the 1.6si its the 25mm valves.... so ur boy wasted money... part from the noise...
- unknown_user
Does make a slight difference but not a huuuuge amount.
Decatting the standard exhaust along with an air filter will make it more responsive though, and the exhaust will sound a lot better without being loud, but you'll fail a roadside emissions check.
- Project
- fiftyoneCL
