Ka spacer plate between rear Beam and hub
3 posts • Page 1 of 1
Hi,
I've heard (god knows where) that the Ford Ka uses a Spacer plate (10mm) between the rear beam and the hub to space the hub out.
Is this true ??
Will this spacer plate fit on a fiesta MK3 rear Beam?
I want to space the rears out, whilst upgrading the brakes to rs2000 specs, without putting an extra load on the bearings...
Is this true ??
- Jur
Tis true the Ka does, and i am also sure the bolt pattern is different, however, if you went to yoour local engineering place no doubt they could make to a plate that size with the correct holes drilled in it.
- James-UK
- Location: Cornwall Drives:Whatever is outside at the time.
