Ka ST170 - 28/03/11 Engine Mount is in. : Member's Gallery - Page 4 | Fiesta Forums
Re: Ka ST170 - 05/11/10 - engine dummy fitted.
Postby knuckles on Sun Nov 07, 2010 11:47 pm
~nomad~ :Nice one mate, no hurry for them, they will be fitted next year lol.
Engine out for pump etc, this will all be new though, and engine out don't bother me really lol
was wondering for my own info.
as watching a timing belt being done on a normal zetec focus is a bit of a squeeze :oooh:
knuckles
Your car: Fiesta Rs turbo
Postby jonyb4 on Mon Nov 08, 2010 12:50 am
knuckles :
put the ka engine on ebay, i got £50 for the same engine from my mk4 earlier this year, it was just the engine with both manifolds and alternator :)
Postby ~nomad~ on Tue Nov 09, 2010 3:26 pm
Did some chop chop just now, basically cut enough out of the inner wing to allow us to bolt the st mount up to the st engine, and then see what will be needed to have it bolt to the car.
After a bit of head scratching we are going to build the chassis / inner wing up to box up to the mount, with a access hole in the inner wing to do the nut up on the mount. I think this is the strongest and neatest solution, and the one that will allow the easiest access to the mount. All in much better than mounting from the rear, which is wrong, wrong, wrong!
Heres some pics then, of a butchered ka!
Also I measured this up a bit when we were at salvage today. I reckon it goes :lol: Next winter maybe!
~nomad~
Your car: Breadvan
Re: Ka ST170 - 09/11/10 - chop chop buzz buzz
Postby Excursion on Tue Nov 09, 2010 3:36 pm
That's the last of the line 225 engine :)
Postby ~nomad~ on Tue Nov 09, 2010 3:43 pm
Yup :) Pretty small aint they? That one is in a S3 as I am sure you are aware! I might buy it lol
~nomad~
Your car: Breadvan
Postby leighk2010 on Tue Nov 09, 2010 4:20 pm
nice idea its what i mite have to do as i want to keep the Stranded mount which the blacktop mounts too, but be so much easier doing it the way you are with a block section with a hole for the mount
leighk2010
Postby Excursion on Tue Nov 09, 2010 4:32 pm
~nomad~ :Yup :) Pretty small aint they? That one is in a S3 as I am sure you are aware! I might buy it lol
The S3 was the worst 'performance' car I have owned :D It looked the part, but didn't do anything very well. I prefer the Zetec to the 1.8T: it was harsh and 'buzzy'
Postby ~nomad~ on Tue Nov 09, 2010 6:05 pm
yeah I know you didnt like it, I have never driven that shape S3, only the current one, which is very good! I did enjoy the engine in the tt though, having lived with it for a while.
For me the 1.8t has good scope for a decent bit of power, for not silly money, which always appears! But its all a "what if" at the mo!
~nomad~
Your car: Breadvan
Postby Minstral on Tue Nov 09, 2010 7:14 pm
thyere was a ka with a 20vt engine in at fitp last year with 4wd, wasnt running though was a wip
Minstral
Your car: *
Postby ~nomad~ on Tue Nov 09, 2010 7:15 pm
yeah i saw that, its was mentalmentalchickenoriental.
~nomad~
Your car: Breadvan
Postby ~nomad~ on Tue Nov 09, 2010 9:03 pm
mate popped over to have a look tonight, as he will be tasked with the welding, going to make the bits to put in this week if I have time, and hopefully get them welded in on the weekend. i will also be modifying the chassis leg to create a bit more clearance for the waterpump pulley. Hopefully by the end of next week all the bits that need modifying in the bay and inner arches will be done, and I can get the dummy engine back out and paint the bay.
~nomad~
Your car: Breadvan
Postby moondustka on Wed Nov 10, 2010 12:33 am
Minstral :thyere was a ka with a 20vt engine in at fitp last year with 4wd, wasnt running though was a wip
That was Joey's. It is running now. Was running at Ford Fair :) Currently building another 20v engine for it.
moondustka
Postby ~nomad~ on Wed Nov 10, 2010 2:02 am
ah so same bloke who built the frs one with rad in the back, seen some videos of it, well mad.
~nomad~
Your car: Breadvan
Postby moondustka on Wed Nov 10, 2010 10:18 pm
Yup :)
moondustka
Postby ~nomad~ on Wed Nov 10, 2010 11:16 pm
Thats a awesome car, although I dont agree with the design of his mounts for blacktop etc :lol:
~nomad~
Your car: Breadvan
Postby jonyb4 on Thu Nov 11, 2010 7:50 pm
~nomad~ :ah so same bloke who built the frs one with rad in the back, seen some videos of it, well mad.
ahh i rmemeber that, is it red?
think i seen it at last years fitp
Postby moondustka on Fri Nov 12, 2010 1:10 am
~nomad~ :Thats a awesome car, although I dont agree with the design of his mounts for blacktop etc :lol:
They weren't originally his design. Lee Blake designed them originally. Joe is the only one who makes them now.
What's wrong with them? :) In a Ka you want Chris Birkbeck's front and rear gearbox mounts. Engine is like rock and no movement. People are under the illusion that it's the CVH style of mounting that causes excess movement. It is Ford's janky gearbox mounts - but then, they were only designed for a 1.3!
moondustka
Postby moondustka on Fri Nov 12, 2010 1:11 am
jonyb4 :
It was black then, but now it's white :)
moondustka
Postby ~nomad~ on Fri Nov 12, 2010 1:19 am
ah its actually the same ka? cool!
its clear that the gearbox mounts are the most important thing in the ka, they seem very good as standard to me, good design, might need to be more solid lol.
But the fact is the rear mounting is a bad idea, it creates a pivot point which is always a bad thing, there is a reason most modern engines in fwd are centrally mounted, and why ford added a front mount to the zetecs.
I am not saying it doesn't work, but the engine can defo be mounted better, people just dont wanna cut their cars up!
Are you still using the Joey / Blakey mount? I think you should go side mount next time you are chopping the car up if so. ou clearly dont mind chopping yours up, and it is better I am sure, I bet you would get the power down better with it!
I keep looking at your thread btw, I am so tempted to chop the front off mine!
~nomad~
Your car: Breadvan
Postby Dave_B on Fri Nov 12, 2010 7:42 pm
chop the front off!!! having seen dan and ben do both of theirs, theres not much to be scared of!!!
few hours with a pipe bender, welder and recip saw you create loads more room and will fit whatever you like in there!!
dave
Dave_B
Postby moondustka on Fri Nov 12, 2010 8:23 pm
Yea it is the same Ka, it was acid dipped and dip primed at aston martin too :o
I agree the side mounting is better for the engine, but I can assure you 80% of the engine movement I had was down to the gearbox mounts. Both are now solid type mounts. The battery tray mount is also a weak point. I managed to snap one when I had the 1.3. They're very thin cast ally! I modified my battery tray to fit over the top of the new mount.
I won't be chopping my car up again :lol: It was a lot of effort!
If you chop the front of yours off and do what we did, you need to lose the plastic reinforcement bar in the bumper. I reckon you don't need to though for that engine. You might as well just keep the standard crossmember. I would deffo get rid of the slam panel and replace it with something. It is just in the way and provides no structure at all really.
And yea I have an original Blakey mount. I think slicks are the answer to seeing the power down :lol: Dan (my brother) is trying them out at the mo! He's got some on 15" escort gti wheels. I need some comps to fit over those brakes I got off you! Bet you're wishing you kept all that now :lol:
moondustka
Postby moondustka on Fri Nov 12, 2010 8:25 pm
Dave_B :chop the front off!!! having seen dan and ben do both of theirs, theres not much to be scared of!!!
dave
Few hours :lol:
... replace that with weeks!
moondustka
Postby ~nomad~ on Fri Nov 12, 2010 9:43 pm
Not wishing I kept anything, I got 2 complete st170s lol!
~nomad~
Your car: Breadvan
Postby leighk2010 on Fri Nov 12, 2010 10:55 pm
~nomad~ :Not wishing I kept anything, I got 2 complete st170s lol!
hmmm 2 you say whats the milage on them :P
leighk2010
Postby ~nomad~ on Fri Nov 12, 2010 11:31 pm
110k and 75k iirc
~nomad~
Your car: Breadvan
Postby fiestasiphil on Sat Nov 13, 2010 10:24 am
awesome project cant wait to see the end result :)
fiestasiphil
Postby moondustka on Sat Nov 13, 2010 11:55 am
Awesome - Put the whole brake setup on it :D happy days
You could probably get away with the ST170 handbrake cable too if you route it right. I've used the ST150 one as it's shorter :)
rallydesign make braided brake lines cheap as well. Will cost about £60 for all 4.
moondustka
Postby ~nomad~ on Mon Nov 15, 2010 12:27 am
gonna use the rears, but i dont think the fronts will go under the 15s :(
Got my Sparco seat off Paul S1 today, so will have a look at whats needed to fit that in the week I think.
The mount hasnt been made up yet, due to time / weather.
Not sure whats gonna get done on the car this week really, gonna be very busy with other stuff :(
~nomad~
Your car: Breadvan
Postby moondustka on Mon Nov 15, 2010 12:43 am
The front brakes only fit under 15" comps..haven't tried under steelies though.
Yea weather is s**t!
moondustka
Postby ~nomad~ on Mon Nov 15, 2010 12:55 am
I dont think they will, Brian tried it. I will have a second look, just need to jack a st170 up and tr a wheel on lol.
Just ordered loads of cutting and grinding discs, happy days :lol:
~nomad~
Your car: Breadvan
Postby ~nomad~ on Fri Nov 19, 2010 6:04 pm
Me and my dog got all the bits chopped about and made up to weld in for the mount now, hopefully get the welding done this weekend. Toying with weld in strut brace too.
~nomad~
Your car: Breadvan
Postby heeman10 on Fri Nov 19, 2010 7:04 pm
Or take another hour to fab up some mounting brackets, weld those to the turret tops, and bolt your strut brace in, so it can be removed when you want to work on fiddly bits :)
Postby ~nomad~ on Fri Nov 19, 2010 7:22 pm
That's what I mean mate, same as the escort boys do. I hate the look of bolt on ones tbh, with the big ring around the strut tops
~nomad~
Your car: Breadvan
Postby heeman10 on Fri Nov 19, 2010 10:54 pm
Ah cool beans :)
Postby jonyb4 on Sat Nov 20, 2010 2:50 am
lol dog.. :lol:
