Ka ST170 - 28/03/11 Engine Mount is in. : Member's Gallery - Page 6 | Fiesta Forums
Re: Ka ST170 - 20/01/11 Small Update Type R Seats
Postby knuckles on Sun Jan 23, 2011 6:38 pm
std bumpers ftw :)
knuckles
Your car: Fiesta Rs turbo
Postby moondustka on Tue Jan 25, 2011 10:29 pm
~nomad~ : Let me know if you want any sport ka bits!
Will do
knuckles :std bumpers ftw :)
Damn right!
moondustka
Re: Ka ST170 - 17/03/11 Small Update Wheels.
Postby ~nomad~ on Thu Mar 17, 2011 9:46 pm
Just a wee update, I trial fitted a wheel i borrowed from S1 with a view to buying the set. They are group A gravel spec escort cossie magnisium OZ wheels. The wheel are 7j (sport ka are 6.5) and obviously esccos offset. Happily they fit well, only tried front but if they work there they will be fine in rear. They need a wee spacer, maybe 3mm to be nicely away from the shock, but there is a bit of room in the arch in any case.
bottom pic shows straight down view, proving they dont stick out! These were trial fitted on a Sportka, so same as mine will be when done.
~nomad~
Your car: Breadvan
Postby RS rob on Thu Mar 17, 2011 9:48 pm
good choice on wheels :Q
RS rob
Postby Smo on Thu Mar 17, 2011 9:52 pm
They'll look great... One of my favourite wheels :D
Smo
Postby jonyb4 on Thu Mar 17, 2011 10:33 pm
oh yes that would work :Q
Postby knuckles on Thu Mar 17, 2011 10:46 pm
Lovely wheels dave :Q
no rubbing on shock or inner wing on full lock ?
knuckles
Postby Smo on Fri Mar 18, 2011 12:10 am
knuckles :no rubbing on shock or inner wing on full lock ?
What, with the not-so-opaque tyre that is fitted? :-?
Smo
Postby Dave G fsi on Fri Mar 18, 2011 12:42 am
Will look really good with those wheels :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby ~nomad~ on Fri Mar 18, 2011 10:33 am
knuckles :Lovely wheels dave :Q
bit difficult to work out without a tyre, the wheel is a couple mm off the shock, so will need a spacer, but nothing massive. This may be different with coilovers too. I thnk they will be fine, they are a inch smaller diameter than sportka ones, so buys me a bit of room there.
~nomad~
Your car: Breadvan
Postby hobomassiv on Sun Mar 20, 2011 1:36 pm
Keep the updates coming! also get a thread going on fk-oc.com the guys there will be interested in seeing this progress.
Im sorting out my sport ka at the moment, have some 300mm st brakes to fit and coilovers to buy at the end of the month. Hope to be running zetec turbo power by FITP, discussing it with a mate who has a garage this week.
Heres some pics of mine so far:
With the tyre rubbing issue, im running ET35 16s and 5mm spacers on the front for my 16"/7.5J if you run 15s ET35 on a normal Ka thats about right, with sport arches you want about ET25 and can go up to 17-18's if you really want
Ka RST - 200BHP!
hobomassiv
Postby ~nomad~ on Fri Mar 25, 2011 11:16 pm
Engine mount welded in :)
~nomad~
Your car: Breadvan
Postby knuckles on Fri Mar 25, 2011 11:34 pm
~nomad~ :Engine mount welded in :)
Woo Hoo ! :D
how did the welder perform ?
pics ?
knuckles
Postby ~nomad~ on Sat Mar 26, 2011 11:58 am
knuckles :
Woo Hoo ! :D
pics ?
i paid a pro to do mount, gonna use your welder to do all the bits and bobs thou, and mount needs tidying as well.
No pics as brian took one and is a chump that will never upload it. Case in point, still ain't seen my track footage from January, which am sure he has now lost :lol: :lol:
Here is a rabbit in shades for now.
~nomad~
Your car: Breadvan
Postby jonyb4 on Sat Mar 26, 2011 2:14 pm
Re: Ka ST170 - 28/03/11 Engine Mount is in.
Postby ~nomad~ on Mon Mar 28, 2011 7:42 pm
Got the mount welded in the other day, it needs tidying and some more bits welding in around it to box everything together, this will all be done once car is stripped back to completely bare i think. Its totally solid, as beating it with Thor the lump hammer confirmed, the whole car moved rather than the mount :lol: Just wants a tidy up. I also need to see how well the SportKa arch liner fits on the engine mount side, and trim it if needed.
we had to get this done so the dummy engine could come out to go in the Dirtbox. Have to strip another Focus for my engine now :lol:
Gave it a blast over in black just to protect it.
~nomad~
Your car: Breadvan
Postby jonyb4 on Mon Mar 28, 2011 9:05 pm
and you call my exhaust mount a bodge, thats just bits of metal welded on top of each other like a bric-o-brac :bonkers:
Postby Ratspeed on Mon Mar 28, 2011 9:09 pm
looks like you welded it too jony! :lol:
Joking aside i cant wait to see what the 170 lump looks like in there :Q
Ratspeed
Postby jonyb4 on Mon Mar 28, 2011 9:12 pm
Ratspeed :looks like you welded it too jony! :lol:
aye joking aside if you wack it good enough and its solid, who gives a f**k?
when's the lump going in? after you strip a focus that is, its gonna go like s**t off a shovel, can see you and brian getting competitive once the fiesta is done :P
Postby Excursion on Mon Mar 28, 2011 9:21 pm
Boys, you've outdone yourselves :lol:
Postby Rhinopower on Mon Mar 28, 2011 10:02 pm
There is nothing wrong with the welding of that mount, particularly as there was f**k all space for the guy to get in there and do it.
Rhinopower
Your car: Volvo FH330
Postby Ratspeed on Mon Mar 28, 2011 10:14 pm
It definately looks strong enough. a good clean up and it should look good :)
Ratspeed
Postby knuckles on Mon Mar 28, 2011 10:49 pm
jonyb4 :and you call my exhaust mount a bodge, thats just bits of metal welded on top of each other like a bric-o-brac :bonkers:
what you have failed to notice jony is the thickness and the width of the box section supporting the mount underneath.
i was there saturday and looked at this myself. it may look a bit untidy but its solid, as dave said it needs more reinforcing from the sides to finish it off.
Should be better than the original ford one when finished :)
knuckles
Postby ~nomad~ on Mon Mar 28, 2011 10:53 pm
lol at people not liking the welds. Done by a VERY experianced welder, took him literelly 5 mins with the engine in place. the reality is, if the other bits were welded in and i had spent 30mins tidying the edges it would look perfect and you would all be wetting yourselves at it. :lol:
bit different to a bodge jony, your lack of knowledge shines through as ever!
~nomad~
Your car: Breadvan
Postby jonyb4 on Mon Mar 28, 2011 11:02 pm
how can you say that when you didnt even weld it yourself?!
anyway like i said, if it holds who cares? most of it wont be seen, namely that square tubing, sometimes theres no other way around a bodge other going mental on money, but lets be honest, it aint worth it on these sorta cars, its just a mess about
you'll be glad to know that exhaust mount is ruined already, too much stress on one of them mini exhaust bushes :rolleyes:
Postby Ratspeed on Mon Mar 28, 2011 11:06 pm
~nomad~ :lol at people not liking the welds. Done by a VERY experianced welder, took him literelly 5 mins with the engine in place. the reality is, if the other bits were welded in and i had spent 30mins tidying the edges it would look perfect and you would all be wetting yourselves at it. :lol:
I'm not slagging the welds, it looks strong. All i'm saying is if it were cleaned up i would be touching myself right now :P
Ratspeed
Postby jonboisescort on Mon Mar 28, 2011 11:08 pm
looks good to me :D :D
aslong as your good with a grinder :lol:
jonboisescort
Car: 1994 Ford Fiesta
Postby jonyb4 on Mon Mar 28, 2011 11:29 pm
might even post the welds in my old mk4 up :bonkers:
Postby jayrs on Mon Mar 28, 2011 11:37 pm
the welding on that mount could be classed as over kill nomad, but imo, thats how it should be, rather over kill than under, looks are not important, it looks a good strong weld (and it didnt move when you beat it one :lol: ) so thats all that matters at the end of the day.
Plus i know what its like to weld in a cramped space, and how bad welds can end up looking (ive had my fair share :lol: ), so that dont look to bad at all! if it matter too much seam seal it or something.
Postby ~nomad~ on Tue Mar 29, 2011 10:30 am
I think they look bad cos the area wasnt really prepped at all, time was very short all round so it was a case of, weld it in so dummy engine can come out for Brian, and tidy it up later. I will weld some little plates around it to cap the ends of the square tube up, and fill the gap left on the inner wing, then grind everything back. Trust me, it will look very tidy when its done.
Jony, you are missing the point a litte, the plan with this car is to have the install of the engine looking as neat as possible, the Dirtbox was very much a exception to how I normally do things, and more a reflection of Brians style :lol: . I prefer things to look right, and trust me, this will do when finished. :)
~nomad~
Your car: Breadvan
Postby Excursion on Tue Mar 29, 2011 11:57 am
Guys, sorry but that isn't the work of a professional welder: there's no where near enough heat gone into that.
Postby ~nomad~ on Tue Mar 29, 2011 12:12 pm
Excursion :Guys, sorry but that isn't the work of a professional welder: there's no where near enough heat gone into that.
For once I am completly going to disagree with you Mark, John has been welding 30 odd years and has done s**t of work for us and have seen plenty of his other work, he is widely regarded as the best welder in the area. The penetration and strength of the welds doesn't lie. Its untidy because the area wasn't prepped, we had to get the mount welded in place so we could remove the engine.
~nomad~
Your car: Breadvan
Postby Excursion on Tue Mar 29, 2011 12:36 pm
~nomad~ :
Lack of prep causes spatter/blobs due to poor electrical contact between pieces or contamination, lack of heat and either a lack of speed with the torch or alternatively wire speed too high causes heaped welds like you have there.
I have will agree to disagree mate.
Postby ~nomad~ on Tue Mar 29, 2011 12:54 pm
Shut up Mark, you can be such as know it all c**t at times. carry on and we are gonna fall out again, and you remember what happened last time.
~nomad~
Your car: Breadvan
Postby Excursion on Tue Mar 29, 2011 1:06 pm
~nomad~ :Shut up Mark, you can be such as know it all c**t at times. carry on and we are gonna fall out again, and you remember what happened last time.
WTF? Why do you always bring that up? Stop PM me abuse as well, that s**t wears really thin. You come across on here as being all pally but you're a snidy c**t really!
