Kent cams for zetec 2i
9 posts • Page 1 of 1
considering getting the cams done on my 16v 2i.
It says on the link below that the cams are £155 per pair exchange, is that £155 for two new cams as long as i swap m old ones with them
http://www.fiesta-centre.co.uk/performanceparts/kentcamspage2.htm#zeteccams
also is there anything else i need to buy like pulleys?
ive only really just started looking into this so i dont know much about it!
so any help/advice would be much appreciated
Cheers, Nick
Cheers, Nick
- Nick 2i
- Phil Si
Car: 2000 BMW 330 Ci
Cheers for the replies
Not sure what to do, dont really wanna spend £500 on some cams
2.0 option sounds good, but i just spend £150 getting the cam belt changed today so it would be a bit stupid to get rid of it as i get it serviced it regularly so its in good shape.
are the 2.0 cams the same as the rs1800 ones?!
Cheers, Nick
Cheers, Nick
- Nick 2i
Obviously you haven't read the Zetec n/a tuning guide yet, have you?
- Project
- fiftyoneCL
Appparently it's best to get your original cams reprofiled. The ally cam bearings in the cylinder head are matched to the wear on your cams, and if you stick different cams in the head, then you may end up with poor oil pressure to the cam bearings.
And you must change the tappets for new ones if you have the cams reprofiled.
- grahamb
When you can pick up a complete 2.0, get it fitted *and* pay the increase in your premium for less than it would cost to get new cams fitted, it's not really a hard choice to make...
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
