KENT CAMS WHICH ONE?
6 posts • Page 1 of 1
i have recently been looking arround for the next upgarde on my FRST and am wondering if you can put a kent 35 cam in a FRST with no engine management mods and how it would perform kent say it can give up to 26bhp extra is this figure acceptable?
Also has anyone tried a FSE boost valve for the same car ? what are they really like?
- RUDEFRST
I spoke to Ahmed about this for PaulR. His recommendation was not to bother with a CVH35 cam on a std 1600 T2 FRST since it doesn't suit the engine at all. It is apparantly better suited for a 1900 T3 FRST.
One option is a Piper 285T2 cam, the other is Ahmed's own FRST cam.
You will notice a difference with the cam, but without having tweaked the ECU map. But, more of an improvement will be made if you have it remapped to suit.
- JJ
PaulR has a point - sort of!
If you FRST is bog standard, your money would be far more wisely spent on a decent exhaust (Magnex), bigger intercooler/chargecooler (Pace) and/or Ahmed chip (£450 fitted, with around 170bhp reliably based on using all std components). Don't waste money on stuff like FSE boost valves and dodgy aftermarket air filters - the std Ford parts are more than adequate!!
- JJ
It also comes down to the mileage of your car, if it has done over 60k it is recommended to change your cam anyway.
I used a "mild" Kent CVH31K cam just to give the engine a little something extra.
As for the 26bhp.......i dont think so.........not on a FRST anyway.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
