kent cvh34
8 posts • Page 1 of 1
kent cvh34
hiya guys i think i have made my mind up and i am going to purchase a kent cvh34 cam kit from burton power i am just wanting to know everybodys opinion who use this cam and alos peoples engine specifications and power output cheers guys much appreciated
- andyb-rst
Re: kent cvh34
burton power are very expencive i used http://cosworth.info/store/index.php?PH ... 02cfba44ca can't go wrong with them loads of people on here and passion ford and as for kent ive seen loads only last a matter of months i used piper t2 cam and it was in the car for 2/3 years when i removed it to sell and still looked like new it is now in a S1 and doing well my car was around 240bhp+ and driven hard i will never use kent it so common that they give you your money back with no problems
- j7aoc
Re: kent cvh34
hiya mate thanks for the reply much appreciated. i know a lad who had the piper 285 and it fooked a couple of his rockers which i heard was common. just bin looking at your pics and the fez looks well
- andyb-rst
Re: kent cvh34
It's stipped mate but my friend had around 4 cam's 2 kent a 2 piper the best one was the piper t2 on power he took the brand new top of the range kent cam out and put the t2 back in thats how good it was, Some one on here or passionford i can't remember sent back hie kent cam as it broke then the one they sent lasted around 3 months
- j7aoc
Re: kent cvh34
The problem with the Kent cams wearing out is due to the oil used during the running in period, you have to use fully mineral oil to allow the cams to harden, if you use semi or fully synthetic the cams can't bed in properly - Kent told me this after they had replaced mine twice luckily they replaced it for free
New Project In Progress!
- mintwhiters
- Your car: Moved onto Motorbikes
Re: kent cvh34
Im sure they would blame the oil
- j7aoc
Re: kent cvh34
I had a piper t2 and it was shagged. Lobes worn to round and the engine hadn't done many miles. Caused me grief with valve bounce!
You have to run a cam in properly or it wont last for sure. brother has cvh34, and I have cvh35. I have no complaints with them.
But, each to their own!
- moondustka
Re: kent cvh34
j7aoc :Im sure they would blame the oil
Ran it in properly with the recommended millars oil and all was well from then on! The tech dept at Kent had been working on the problem for a long time and had only just figured it out when I sent them detailed intructions on how I ran it in... everything spot on apart from the oil... apparently can happen with a few other engine bits depending on materials used..... so basically when installing new components use 'millars running in' oil for first 250-500 then change for the same for 250-500 miles then put in the fully synthetic
- mintwhiters
