Knocking noise when turning right
14 posts • Page 1 of 1
Ive got new wishbones on either side of the car. Couple of days ago when ever i do a hard turn right theres a knocking noise, like crank. Im going to do the tracking today bcoz its fcuking s**t driving it. So what can it be? probably find it out l8r when its up the ramps.
Cheers peeps.
Cheers peeps.
- butler_29
wheel nuts.
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
correct CV JOINT, had it tracked. The guy said it was dry not much grease init. Is it worth getting a brand new part or a second hand on? That means ill have to get the left inner and outter and right inner and outter. Ive gotta qoute and that was £160 just for the parts.
Cheers PPPL
Cheers PPPL
- butler_29
If its only wen u stear 1 way only it can be a drive shaft.
Fezzy Loving...Street-Stylers-Southwest.co.uk
- Stuie-Little
- Location: North Devon. Drive's Nothink as some muppet wrote myRS off
cv joints
Left inner? 37.50
Left outer? 43.75
Right inner? 37.50
Right outer? 43.75
Drive shaft kit
96.88
if i return the old part i get £25 bk
Thats one place carparts-direct.co.uk
Ill try all the local car parts shop
Ill try general traffic motors
check this video out
http://www.polosie.pl/eng/film/motomax_demo.avi
very interesting
ill change all the lot i do 450miles a week nearly
Left inner? 37.50
Left outer? 43.75
Right inner? 37.50
Right outer? 43.75
Drive shaft kit
96.88
very interesting
- butler_29
I had something similar to this a while back!!
Get it looked at, thats all I can say! I was getting a knock steering right, only at a particular degree as i turned.
Turned out to be the steering knuckle - the knocking stopped when the knuckle ripped the splines on a corner sending me into a verge
Not nice, have it looked at mate
- Rusey
hey butler im getting EXACTLY the same as you, knocking sound from the wheel area, when turning right. Im also getting that humming noise! Im gonna take it to the garage 2day.
- wakeboardtom
Hey Butler, my car is now in the garage, Wheel Bearings had gone on mine, so its getting fixed now. Have u got yours sorted? Sounds like you need new bearings like me, or have bent something down at the front end somewhere.
- wakeboardtom
- wakeboardtom
