lame mk3 lower arms question
33 posts • Page 1 of 1
the rubbers on mine never last!
not interested in adjusting camber etc
just want them to last longer and be more solid!
anyone done or know what can be done??
- GavStyli
- Your car: Fiesta Turbo
- GavStyli
do you still use the car on the road much?
rose jointed would be good, but not if your using it daily ase they wear with all the crap of the road apparently
you only really have 3 choices afaik
standard - Cr@p as you say
polly bushed - last time i heard seems to be as much if not more of an issue with these than the gearbox mounts!
rose jointed - as i explained above
- FezzR
- God Damn Lazy
hi ian, yes used daily so forget the rose jointed ones then
so whats the pros and cons of the polly bushed??
- GavStyli
GavStyli :hi ian, yes used daily so forget the rose jointed ones then
in theory they are a stronger more durable rubber
in practice they are usually floored and split, wrong compound, poor design, ive brought some for mine about 18ths ago (second hand but not used) and when they turned up i refused to fit them as they were utter bollox, forget which make though
- FezzR
- God Damn Lazy
Get powerflex poly bushes. Never had any problems with mine.
Might be an idea to get them fitted proffesionally, as i whacked them in with a sledgehammer and it was hard work (also i think i could have broken something as a little o-ring popped out )
- Raymondo
so can i just take the current arms off and get powerflex poly bushes on them? can you just order a set of pushes for the lower arms only?
- GavStyli
you need to order bottom arm front and rear bushes (total of £50 for both sides) then you take your old arms off, get the old bushes pressed out and the new ones pushed in.
i would recommend finding a few people already using them and get reviews first though
- FezzR
- God Damn Lazy
This guy is selling an unused set for the whole car, normally around £200 + p&p new.....
http://www.fiestaturbo.com/forums/about129872.html
- CRF
CRF :This guy is selling an unused set for the whole car, normally around £200 + p&p new.....
thanks geeza but only want the ones for the lower arms, how many on each arm ?? anyone got any pics of these in place?
- GavStyli
- CRF
- GavStyli
Good topic!
I was going to use the rose jointed stuff, but decided against it for a road car. Got to admit i was tempted by the Deflex complete wishbones for £179 per pair ..... but i guess thats a big NO for using them then ?
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
funny you should mention the deflex arms, i noticed them this morning on theyre sight, they do have aspects of good design (manufactures have quite radically redesigned arms in the past few years) with the solid design as apposed to the old pressed steal spot welded together, obviously in an attempt to improve handling as the sacrafise for weight.
if it was a company other than deflex then i would say they are well worth a try, but you can only judge them on past performance until they are independanly tested. so i would stay clear untill then sadly.
HTH
HTH
- FezzR
- God Damn Lazy
just to add... i was searching to find a pic of the mondern style arms when low and behold a link to mr Excursions topic linked up on google, Mark's using "Sport Ka arms which are cast for strength".
Although they are not of the design i was thinking they look like they could be a good midway point between old and new, and "if" they are a straight fit (which is possible) and most likely have better designed bushes, could well be onto a winner.
- FezzR
- God Damn Lazy
my old mk1 escort had rose jointed front suspension. felt superb on the road but i must admit to dodging the pot holes! fook that absolutly no give at all. not funny
- 285Andy
- Your car: fiesta rs turbo
285Andy :my old mk1 escort had rose jointed front suspension. felt superb on the road but i must admit to dodging the pot holes! fook that absolutly no give at all. not funny
what sort of wear rate were you getting in the winter with road salt and crap?
- FezzR
- God Damn Lazy
didnt used to use it in winter myself. although this car has had them on for aound 3 years and the new owner hasnt changed them so im assuming he's had no problem with them??
- 285Andy
I haven't yet got to the lower arms issue, but I know my std ones are not up to the job (even now with the car still on axle stands )
The only this that I need to sort the handling is camber and caster. Camber is easly done but caster... I would need somewhere near 3 positive caster. Any ideas (besides zoo motorsport lower arms)?
Regarding the bushes: the best compromise is the powerflex ones.
- BUTRE
I myself have the deflex lower arm bushes:
And they work well on my car (not a daily driver) .. they tend to squick a bit.. but that's all. feel is excelent.. But the installment is a H E L L of a job.. ... and you have to lign them up perfectly...
The rose jointed have to be greased every 7k miles or so .. but heard good stories about them ..
Last year on FITP pumaspeed had some full rubber ones bushes, in stead of the standard bushes (which aren't full rubber) these need to be pressed in the standard arm..
- Jur
- paradox
When talking about this I think its best to everyone quote their bhp. Std lower arms (when new) are fine for std FRST bhp, but once you hike the boost... hell breaks loose and the car just torque steers.
Anyone with a 200bhp FRST on powerflex or deflex lower arms bushes?
And are they to coupe with 200bhp when drag racing?
- BUTRE
- GavStyli
BUTRE :TIL13R, are they camber adjustable?
Is there any info from deflex about castor?
No they arnt adj im affraid
http://www.defelx.com click on the new products bit
Tiller
- TIL13R
