Lost gears ST150
Lost gears ST150
Postby tris on Thu Jan 02, 2014 7:01 pm
Hi all, i have seem to have lost my 2nd 4th and reverse gear ( all on a down throw with the gear lever) in my fiesta st150. i was out driving the other day going up a slip road i went to drop it down in to second but the gear wasnt there, i got the car home with 1st 3rd and 5th. There was no whinning sound before hand and no poping out of gear. the gear lever now when in third looks like its in neutral. It will grind 4th but wont engage. if any one has any idea or has had a similar problem any insight would be greatly appreciated.
tris
Lost gears ST150
Postby elPaulio on Thu Jan 02, 2014 7:25 pm
Sounds like your gear selector has slipped off the gearbox stud.
If it's anything like a mk3 then get under the car, undo the bolt and move the connector further forward and secure it.
Bit of trial and error will be needed to realign it but sounds like it should work
Paul
Fiesta Si 2.0 16v
Mods: K&N 57i, 2.0 Silvertop, Samcos, GAZ Coilovers, Quaife Straight cut box, Wilwood 4-pots, stripped out track female provider of 'horizontal refreshment'
Planned: GSX-R 1000 ITB's, ST170 4-2-1 Manifold, Megasquirt 2 ECU, OBP Pedal box :)
elPaulio
Your car: Mk3 Fiesta 2.0 Zetec Si
Re: Lost gears ST150
Postby russ-RST on Fri Jan 03, 2014 8:54 pm
As said sounds like the gear linkage has come loose or mis aligned, doubt it would be anything internal being it selects the other gears ok. But I thought these had cable shift MTX boxes?
russ-RST
Your car: fiesta rs turbo
Postby andymac on Fri Jan 03, 2014 11:24 pm
Cables stretch, go out of adjustment. It's not unheard of, even for a cable select box.
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
