LOW COMP PISTONS?
12 posts • Page 1 of 1
LOW COMP PISTONS?
Whats the difference with these type pistons?
- Fez Si Boy
basically they have a dish or sum type of effect on the top, where as normal piston are flat. creating a lower compression.
they are also stronger i think
again. i no nothing
again. i no nothing
- ianFRST
Low compression pistons lower the compression during the compression stroke Stupid sentence Basically, the fuel mixture can get so hot from squashing it (Take a bit of Boyles' theory work....P1V1/T1 = P2V2/T2) that it detonates before TDC, so low comp pistons allow correct ignition, and a better ignition too Ahh good old A level Physics
You learn about low comp pistons in Physics ??
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Just remember Boyle had some useful things to tell us about the behaviour of gases in compression My physics teacher was a simple man...once worked out bullets travel at 18 m/s
KEVFRST :Them aliens moved on from crop circles I c.
Oh and btw, please excuse my double-posting on this thread and one or two others, uni internet doesn't like FT
Fez Si Boy :Can you get these pistons for a Fiesta Si 1.6 engine?
You can, but you will only loose power..
low compression pistons are made for Turbo engines to run higher boost.
For an atmospherical engine higher compression gives more power (with a certain limit off course)
- Jur
