Low Sitting Brake Pedal
10 posts • Page 1 of 1
Since messing about with the pedal box to change the clutch ratchet, I can't help but notice the brake pedal sits rather low! The brakelight switch is also right on the edge too.
I've changed the white plastic collar/tube/spacer since that was cracked but it's still pretty low... lower than the throttle pedal!
Any ideas?
Any ideas?
- Tweek
- Your car: VW Golf GTD
Re: Low Sitting Brake Pedal
daft answer as you are more than capable of doing it right, but is the pedal box fully bolted back in, 2 bolts by the pedal are the brake bar bolts. might be why its sitting back a bit
- AW0L
Yeah, everything bolted up tight to my knowledge. Worth a re-check though!
- Tweek
Still haven't figured this out!
- Tweek
Have you fitted a mondeo brake servo? This set mine back a bit, had to fit different plastic bit at the pedal where the rod joins.
Si.
Si.
1991 Fiesta RS Turbo - Project Thread - 285.8bhp, 320ft/lbs - Sold to a good friend .
- Simon84uk
- Your car: Fiesta RS Turbo
Aha, yes! And I know the piece you mean, what did you replace it with? It concerns me the pedal is held up by plastic lol.
- Tweek
It was about 2 years ago I done this, from memory I got a few down the scrappy from rounder escorts (mk5?) or maybe even a mk2 mondeo. But I can't be 100% sure, might have even been a mk3.5 fiesta as I remember taking some PAS parts from that at same time. Sorry can't be definite on it, was a long time ago. I haven't fitted the servo since I reshelled as have gone down the aftermarket pedal box route.
Hope it gives you a starting point at least
Si
Si
- Simon84uk
Think the part I mean is the 2 inch long white, flared plastic tube. Thinking about it again I might have just got the spring clip from the 3.5 fiesta, which I broke on mine.
Si.
Si.
- Simon84uk
Sorry to keep posting, another thing popped back into mind... I tried taking 10-15mm off the servo mounting brackets which brought it the actuating rod back to the position it needed.
I took too much out though it turned out and ended up putting 3mm washers between the bracket and servo. I think I still got them attached to my servo if you wanted me to post them up to try? washers might be attached too if lucky.
Si.
Si.
- Simon84uk
Fixed this now, I think/hope!
I got under the brake pedal and put a few washers between the thick plastic stopper/spacer and the larger side of the shaft and placed the stopper back on top.
This then made the white tube too long so cut about 5mm or so off the end of that and it's now sitting perfectly.
I'm not entirely sure what implications this will have (if any) on the brake function since the bar is further round than normal but we'll soon find out lol.
Cheers for the help, it gave me some ideas to tinker with
- Tweek
