Lower arm differences
7 posts • Page 1 of 1
Need a quick answer, is there different part numbers for xr2i and frst lower arms or is it a one size fits all, I know the steering racks are different so was just wondering
- dannyboy
Fiesta xr2i lower arm's are the same as the rs turbo one's ford call them ARM-FRONT SUSP part number - 1054984 & 1045985 £58.36+vat each if you get discount there £37.93+vat
- j7aoc
- j7aoc
Don't know if its really true but read someone here used the 1.1 lower arms to get less negative camber.
The only way to get this is if the 1.1 lower arms are less wider than the FRST/XR2i ones.
Can anyone confirm this?
- BUTRE
The std FRST/XR2i lower arms have 3 "nails" holding the end of the lower arm. non-FRST/XR2i only have 2. Now Fiesta Frenzy adjustable lower arms are originaly from Ford and moded and they have only 2.
Did Ian Howel used the non-FRST/XR2i lower arms? It would make sense since to get less negative camber you'll have to push the wheel in and with the std FRST/XR2i lower arms there would not be enough working space for this.
I hope that everybody understands my point of view
- BUTRE
