Lower arms Fiesta frenzy or Zoo motorsport
15 posts • Page 1 of 1
I know that quite a few people have these but I can't decide between the two?
Any advice from anyone, which one is better, any problems?
Someone who had a very quick zt has already told me that zoo ones are a lot heavier, I'm not naming any names just want an opinion please before I order a pair
- boost300
They both do the same job very well its just the price that i don't know of?
- freak power
Ive got the Zoo one although i havent fitted them yet. They are not to much heavier than a std lower arm. I think there better than the fiesta frenzy ones caue they look alot stronger you can change castor aswell as camber and they built from scratch rather than being a std item modified.
I have some std lower arms machined like the fiesta frenzy ones with deflex bushs i would sell. Pics in gallery if your interested
- Sunil_FiestaRS_16V
these zoo motorsport arms
are they rose-jointed?
how much are they?
JJ
how much are they?
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
I'm really interested on the "Front tubular wishbones - adjustable camber & castor" from ZOOMotorsport. Does any one have photos?
Also, on their website they "Add Rose jointed bottom ball joint to Front tubular wishbone kit +£40". Whats this?
Found this photos:
I think that this are photos from their cossie front tubular wishbones.
Found this photos:
- BUTRE
those are pictures of my car what do you want to know?
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
When you adjust the camber with those lower arms, doesnt it move the whole wheel in and out of the arch in an arch, instead of pivoting about the centre of the wheel?
- Sphinx
FezzR :off topic, in pic are those 2wd cossie 4pots? if so they look a hell off a lot easier to fit then people make out
no there wilwood DL
- turboboss
sphinx :When you adjust the camber with those lower arms, doesnt it move the whole wheel in and out of the arch in an arch, instead of pivoting about the centre of the wheel?
no only the bottom of the wheel moves plus you can adjust the castor
- turboboss
These sort of suspension components look excellent for the track, but I can't see that they'll stand up to normal road use? Ie 36k mile intervals to replacement etc
I'm not interested, but for everyones sake what is the advice that comes with them with regards service/inspection intervals?
Excursion :These sort of suspension components look excellent for the track, but I can't see that they'll stand up to normal road use? Ie 36k mile intervals to replacement etc
i'll have to ask karl bromley @ zoo motorsport they are proper rose joints which should last the lifetime of the car but i dont know for sure i will tell you tomorrow
- turboboss
turboboss :Excursion :These sort of suspension components look excellent for the track, but I can't see that they'll stand up to normal road use? Ie 36k mile intervals to replacement etc
ive heard the opposite about rose joints because they have no protection from dirt grit salt and grime
- FezzR
- God Damn Lazy
Excursion :
I really want solutions to sort the track geometry on the fiesta, but 36k miles service (which can be expensive) or less its not a good solution for a road car.
By looking to the std arms, they also can be moded to change castor, but it will not be so easy to try diferent castors. Oh well, once you know the castor to use, the damn thing can be welded anyway, unless its a track car that needs to be setuped up for every race.
- BUTRE
