lowering springs on factory shocks
Postby fastfezz on Sun Jul 21, 2013 10:11 pm
hi im looking into getting 60mm springs from a manufacture of ebay called pi
http://www.ebay.co.uk/itm/PI-Ford-Fiest ... 0407548112
and was wondering will i be able to place these in factory shocks or will i have to get other shocks
thanks
fastfezz
Your car: ford fiesta
Re: lowering springs on factory shocks
Postby fastfezz on Sun Jul 21, 2013 10:17 pm
or if anyone got any others thay would recommend that would be great too
thanks
fastfezz
Postby MK4 Rick on Mon Jul 22, 2013 8:27 am
Ive just fitted brand new 60mm springs to my std shocks and they fit no problem and no slack any where :D
MK4 Rick
Your car: Mk5 Fiesta
Postby MK4 Rick on Mon Jul 22, 2013 8:30 am
MK4 Rick
Postby russ-RST on Mon Jul 22, 2013 9:04 am
They will fit fine, just don't expect it to handle amazing or for your shock absorbers to last very long. You want proper uprated and shortened shocks ideally, someone like gmax,spax etc will do them, if yours is a mk3 they pop
Up quite regularly on here for ~£100 a set 2nd hand
russ-RST
Your car: fiesta rs turbo
Postby fastfezz on Mon Jul 22, 2013 6:11 pm
thanks for all the advice really appreciate it
thanks
fastfezz
Postby Tweek on Mon Jul 22, 2013 7:09 pm
I tried it with -35mm springs. Was ok until some bigger bumps where the shocks bottomed out and made a loud bang lol.
Your car: VW Golf GTD
Postby fastfezz on Mon Jul 22, 2013 7:56 pm
Tweek :I tried it with -35mm springs. Was ok until some bigger bumps where the shocks bottomed out and made a loud bang lol.
so did you find out what caused the bang?
fastfezz
Postby Tweek on Mon Jul 22, 2013 8:01 pm
Well yeah, where the spring was short and the shock was still the std length, the piston on the shock hit the bottom.
Postby russ-RST on Mon Jul 22, 2013 9:26 pm
Tweek :Well yeah, where the spring was short and the shock was still the std length, the piston on the shock hit the bottom.
This is why shortened shocks are suggested plus the standard shocks will be soft in comparison to the spring and will end with a very bouncy car lol
Russ
russ-RST
