MAHLE Forged 86mm Pistons (Fiesta ZVH Turbo)
Postby rzrdan on Mon Jan 26, 2015 12:27 pm
Good condition Mahle Forged Pistons they are 86mm with a 21mm pin so will fit standard size rods.
These mahle forged are made from a M124 (similar to 4032) alloy which has low expansion and piston to wall clearance can be as little as 0.04mm which I believe is quite a bit smaller than other brands require. They should last longer and be quieter (no piston slap) which is more suitable for a daily driver.
These are early C20XE Red Top pistons and are forged unlike the later ones.
They can be fitted to Fiesta ZVH engines and give a 7.5:1 CR which is ideal if building a turbocharged engine.
On a Zetec they give 8.9:1
They can be fitted to a Rover T16 engine and give a 9:1 CR on standard size rods. Although they can be machined down to lower compression if needed. Or you could have the block skimmed and have a higher compression ratio as these sit 2.07mm from deck on a standard T16 block
Set of 4 with Pins and Clips
£110
rzrdan
Your car: MG ZR
Re: C20XE MAHLE Forged 86p Pistons (Fiesta ZVH Turbo)
Postby rzrdan on Sun Feb 01, 2015 12:27 am
Bttt
rzrdan
Your car: MG ZR
Re: MAHLE Forged 86mm Pistons (Fiesta ZVH Turbo)
Postby J03 on Thu Feb 05, 2015 9:45 am
Is a set of these still available?
J03
Your car: Ford fiesta Mk4
Postby rzrdan on Thu Feb 05, 2015 9:05 pm
J03 :Is a set of these still available?
Yes, Pm'd you.
rzrdan
Your car: MG ZR
Postby rzrdan on Thu Mar 12, 2015 12:56 pm
Still got 2 sets available
rzrdan
Your car: MG ZR
Postby Tweek on Thu Mar 12, 2015 9:29 pm
Interested in a set of these. What compression ratio do they provide on full Zetec engine do you know?
Your car: VW Golf GTD
Postby rzrdan on Mon Mar 16, 2015 10:27 am
Pm'd
rzrdan
Your car: MG ZR
Postby Ice 159 on Tue Mar 17, 2015 11:30 pm
What compression ratio do they provide on full Zetec engine do you know? Where are you located? Regards
Ice 159
Your car: 1990 Fiesta RS Turbo
Postby rzrdan on Thu Mar 19, 2015 8:12 pm
one set left
rzrdan
Your car: MG ZR
