Megasquirt ECU Fitted!Throttle Bodies Running!New Head!!PG10
Postby PaulC on Mon Jun 27, 2005 8:36 pm
Great news Asad :D Its sounds like the bloke was pretty much able to start messing with the MS straight away? Its an advantag if anybody with a brain can tune it :D
PaulC
Postby Asad on Mon Jun 27, 2005 8:44 pm
You'd be surprised how easy it is!
The only thing the rolling road makes easy is holding at a certain speed/MAP.
You basically sit at a certain rpm?BAR, lets say 3000 rpm and 50kpa. On the realtime tuning, you see a green dot, showing you where you are on the Fuel map.
You press "F" so that you can adjust the nearest bin. Then depending on whether it is running rich or weak, you adjust the mixture using "Shift" and "Up arrow" or "down arrow".
He adjusted it rich as a start point, and was gonna dial it back in, but we didnt get to it. Thats where the datalog comes in. You compare the graph, and say you want to be 10% leaner, just go back to the fuel map and make the adjustment.
Ive tried to make my map smoother, as I always have the RR map on file to go back to!
When you getting round to getting yours? :wink:
Asad
Asad
Postby PaulC on Mon Jun 27, 2005 9:28 pm
Great stuff :D
Its on my list, and I think mmo is adding it to his list of things to do.
Hopefully when my insurance comes round for renewal in september I'm going to drop a 2.0 in and so will be using MS then I hope :wink:
PaulC
Postby FezzR on Mon Jun 27, 2005 10:17 pm
did he not have det cans for tuning in the ignition advance?
FezzR
God Damn Lazy
God Damn Lazy
Postby Asad on Mon Jun 27, 2005 10:20 pm
To be honest, we didnt even finish fuel map tuning let alone spark!
Im happy with the results though. I plan on playing with it a lot myself, and in the meantime sorting out the throttle bodies.
Once I have done all that, I will go back with it set to RPM V throttle as apprently thats easier to tune.
Asad
Asad
Postby FezzR on Mon Jun 27, 2005 10:44 pm
i would recommend against tuning advance unless you have some kind of knock sensing display, could easily end up with a fooked engine
FezzR
God Damn Lazy
God Damn Lazy
Postby SimonT on Thu Jul 21, 2005 10:49 am
I love this topic!
One of the best threads on this board I reckon!
Asad hows progress so far? :)
Too old and too bald.
SimonT
Your car: Fiesta Zetec S TDCi
Postby Asad on Thu Jul 21, 2005 7:23 pm
Hi mate,
Its good! The car drives perfectly (touch wood). Idles better than before and pulls hard all the way. Plus, I can drive it lightly and get decent mpg out of it.
Im trying to source an ST170 inlet manifold so I can get my TB's on, and also a good Exhaust manifold.
Tuning wise, I have set it up good on the Megasquirt. Ive got it to start first time and idle great when cold. It idles around 850rpm without any problems.
I had a thought at the back of my mind that I would always need to adjust this or that but its been perfect. hasn't skipped a beat! Even when my O2 sensor went, there were no problems with driving it!
I'd definately recommend it as its soo easy and you get a load of control.
Something tells me you might already be on the case........
Asad
Asad
Postby wroey on Fri Jul 22, 2005 10:38 am
Top topic saw these on the net a bit ago but looked like too much hard work!
Keep it up :D
Bye Bye Si
wroey
Postby Asad on Wed Aug 10, 2005 7:21 pm
This should be coming tomorrow:-
On the MS front, I have been messing around with the maps. I revised the spark map and it feels much better.
But I did notice that my injectors were maxing out. Now I'm getting the ST170 manifold, I will either use injectors, fit the whole manifold or use it to fit my bike TBs.
Just exhaust manifold left.
Asad
Asad
Postby PaulC on Wed Aug 10, 2005 9:29 pm
:o Is that going to fit mate? It actually looks like it will :D
PaulC
Postby Asad on Thu Aug 11, 2005 7:54 am
:wink:
Manifold will definatley bolt onto engine, with the bonus of the ports being matched.
The manifold actually comes apart just after the injectors and can be used to mount TBs!
Saves having a manifold fabricated.
Should get it later today... more pics then!
Asad
Asad
Postby PaulC on Thu Aug 11, 2005 8:33 am
:D :Q
When I said "fit" I was reffering to the clearance to the brake bar, but it doesnt look much bigger than a focus inlet in that pic :oooh:
PaulC
Postby Asad on Thu Aug 11, 2005 8:57 am
hopefully :D
Asad
Postby chris-fiesta on Thu Aug 11, 2005 9:05 am
gonna be sweet m8, keep up the good work!!
chris-fiesta
Postby sailorbob on Thu Aug 11, 2005 9:32 am
Can you control the dual tract on the inlet with the MS too?
sailorbob
Postby Asad on Thu Aug 11, 2005 9:45 am
What do you mean?
Asad
Asad
Postby sailorbob on Thu Aug 11, 2005 10:09 am
The ST170 has dual stage intake (DSI) manifold, using long runners for low-end torque at low revs and shorter runners for higher peak power outputs at higher revs. On the ST170 the ecu controls the switch over point.
sailorbob
Postby Asad on Thu Aug 11, 2005 10:18 am
Ah.
Ermmm.
I guess this will not be an issue with bike TBs but only if I use the whole manifold.
In what way does it work? Does it increase fuel? What adjustment does it make? It may be possible to program the MS to take on this role.
If there is no way to mimic this, and my bike TBs are not ready, I may just use the injectors in my existing manifold. This will sort my maxxed out injectors.
Asad
Asad
Postby SimonT on Thu Aug 11, 2005 10:28 am
asad may i suggest RS2000 injectors in your current fuel rail.
might be worth doing while you butcher that st170 to fit your bike TB's
the rs2k injectors are good for 200bhp and are a simiar ohm rating to the fiesta/mondeo ones
SimonT
Postby Asad on Thu Aug 11, 2005 10:40 am
I'll have a look into the cost of that.
Re:- fitting bike TBs. The manifold does not require any work. Just changing of the Fuel pressure regulator. Thats the great thing. Where you see it split and with the rubber pipes, thats how it is standard!
Only the bike TBs need spacing out.
Pics are from this thread, where richard has used this method. Its where I got the idea from:-
http://forums.turbosport.co.uk/bbs/show ... ge=1&pp=20
Is there a reason not to use the ST170 injectors in my fuel rail? Different type? Will not fit?
Asad
Asad
Postby SimonT on Thu Aug 11, 2005 10:45 am
yeah they are top fed (like the frst) and wont fit.
you need side fed injectors. rs2k ones can be picked up for 50 quid a set second hand.
i was gonna use them in the zetec turbo i was building
SimonT
Postby sailorbob on Thu Aug 11, 2005 10:48 am
Usually DSI manifolds have butterflys in them that direct the air through the short or long tracts as desired. Control of them is by vacuum diapraghm actuator with solenoid or motorised actuator depending on the car. A solenoid one should be easy enough to get working with the MS if you have a spare output circuit (I'm sure someone must have written the code for this kind of thing). You could decide upon the rpm switch point by doing two power runs, one with the short tract only and one with the longer tract only (downside is you would need to have separate maps for each try). You then compare the two graphs and see where the cross over is, set the changeover at this point and create a hybrid of the two sets of maps to suit.
Hopefully I will have a similar task to do myself with a 4AGE engine that has TVIS on it. :)
sailorbob
Postby Asad on Thu Aug 11, 2005 10:55 am
Simon - I see what you mean. I dont think I'll get the RS2k injectors as I am looking to use this manifold very soon. I was thinking I could use the ST170 but seeing as I cant, Ill just wait until I have the whole manifold on.
Saliorbob - Thanks for the info. If it is indeed solenoid operated, then yes, MS could control it. I will have a look at the manifold when I get home. If it does have a butterfly, I may end up just leaving it open/closed as its only temporary.
My main objective is to get Bike TBs on. Use the complete ST170 manifold would just be the convinence of having the ST170 manifold working and have better injectors.
Thanks for all the info guys.
Asad
Asad
Postby Max M4X WW on Thu Aug 11, 2005 12:02 pm
Thats a class way of fitting TB's!
Does this inlet have some swingy round thing? Rememebr looking at Excursions site about it.
Postby sailorbob on Thu Aug 11, 2005 12:27 pm
Ahh yes, it's not butterflys in the ST170, pretty pics at http://www.mwstewart.co.uk/index.php?co ... vvt_engine
sailorbob
Postby Asad on Thu Aug 11, 2005 12:38 pm
LOL
That has made my life easier!
Asad
Asad
Postby PaulC on Thu Aug 11, 2005 12:43 pm
SimonT :yeah they are top fed (like the frst) and wont fit.
PaulC
Postby Asad on Thu Aug 11, 2005 6:59 pm
Right,
This was waiting for me when I got home! Big Box! :o
Fuel rail was seperate and a little oily :-
And heres a better pic of the rubber pipes, with the fuel rail off :-
Im not sure it will clear the brake bar or not... but will check later.
Plus, the Kawasaki TBs I have will not space out easily too fit. :(
So I'm gonna put them up for sale and try and source some with 90mm centres!
Asad
Asad
Postby Asad on Mon Aug 15, 2005 11:22 pm
These arrived today!
Close up:-
Airbox removed!
Here its lined up next to the ST170 inlet:-
You can see its not centred:-
I then stripped all the bits I dont need, secondary butterflies etc :-
Here they are split up :-
And with the ST170 inlet sitting on them! :-
Back view :-
Will hopefully get a bit done this week and on the weekend. Need to size spacers etc.
I want to get them on and running before Trax, but I'm not sure if I will as I may be going away for work.
Asad
Asad
Postby Max M4X WW on Mon Aug 15, 2005 11:29 pm
Whats that lot from then?
Id love this lot to be on before trax looks proper sweet and i could have a nosey :Q
Postby Asad on Mon Aug 15, 2005 11:34 pm
:D Me too!
ST170 manifold and GSXR1000 42mm throttle bodies.
Asad
Postby OrionZetec on Wed Aug 24, 2005 2:10 pm
Pure genius ASAD :)
You showing at trax? Be nice to have a butchers ;)
Keep up the amazing work :) Youre opening many doors to thousands of Zetec owners 8) 8)
OrionZetec
Postby XRMike on Wed Aug 24, 2005 5:32 pm
and potentiel zetec owners! :D [/quote]
XRMike
Postby Asad on Wed Aug 24, 2005 5:42 pm
Cheers guys!
Should have more updates this weekend.
I have brand new 330cc Injectors on the way, for a good price....
http://cgi.ebay.co.uk/Sets-of-Four-New- ... dZViewItem
I will be using the ST170 manifold after all, with an adaptor to improve air flow. Pics later.
All that will remain is a decent exhaust manifold :D
Then another trip to the rollers for a setup.
Asad
Asad
