Megasquirt ECU Fitted!Throttle Bodies Running!New Head!!PG10 : Member's Gallery - Page 9 | Fiesta Forums
Postby FezzR on Mon Sep 26, 2005 10:07 pm
is it running yet?
did you look at importing it rather than the more expensive uk supplier?
are you running V3 board with MSII ?
FezzR
God Damn Lazy
God Damn Lazy
Postby Asad on Mon Sep 26, 2005 10:15 pm
Got 3 out of 6 bolts, some EFI fuel hose and clips.
Sorted out the fuel rail, just need to plumb into the return and feed.
Was your post aimed at me? :-?
Im running MS with V2.2 board.
Asad
Asad
Postby FezzR on Mon Sep 26, 2005 10:29 pm
Asad :Got 3 out of 6 bolts, some EFI fuel hose and clips.
Asad
yes mate was aimed at you added you to msn to ask loads of questions lol
FezzR
God Damn Lazy
God Damn Lazy
Postby Asad on Mon Sep 26, 2005 10:30 pm
lol
I think you been on my list for ages anyway!
Fire away!
Asad
Postby andyhardy on Mon Sep 26, 2005 11:21 pm
Asad :LMA011 - Oil Gauge T-Piece Short
1/4NPT * 1/4NPT * 1/8NPT
LMA007
Oil Pipe Adaptor
1/8BSP to 1/8NPT
Remeber though, that this doesnt provide a temperature reading.
Thanks for the part numbers mate - it's ok regarding the temp sender as I already have one like yours anyway ;)
Postby Asad on Wed Sep 28, 2005 8:25 pm
As I get home round half six, its too dark to properly finish this off.
So in the mean time I have been sorting out the fuel pipes and throttle cable bracket.
I'll post pics of the fuel piping later.
But here is how I managed to stick with the ford throttle cable :D
I started off with the bracket with the edge cut off:-
The lower corner was going to be bolted down:-
But as you can see, the cable does not line up properly with the bracket:-
So I made the hole for the second bolt :-
And I bent the bracket into place so that it would line up correctly :-
Finished product! :-
Oh and I also had to use a 8mm drill bit to enlarge the nipple hole slightly. Otherwise the Ford cable nipple wouldnt fit.
I tested it with the cable in place and it worked as it should! Not catching anywhere, and full throttle opening was achieveable.
Not much left but to bolt it all on. Roll on the weekend!
Asad
Asad
Postby Excursion on Wed Sep 28, 2005 8:48 pm
Asad :As I get home round half six
Asad : properly finish this off.
Asad : I made the hole
Asad : bent
Asad :enlarge the nipple hole
I thought as much, sounds like a pretty normal evening for you :lol:
Postby Asad on Wed Sep 28, 2005 8:52 pm
Excursion :
Asad : bent
I thought as much, sounds like a pretty normal evening for us :lol:
Why i oughta!
Asad
Postby Excursion on Wed Sep 28, 2005 8:58 pm
:oooh:
Postby ant pittaway on Wed Sep 28, 2005 10:12 pm
ant pittaway
Postby andymac on Wed Sep 28, 2005 10:29 pm
Asad :
Excursion :
Asad : bent
Why i oughta!
Promises, promises hey :wink: Looks like Excursion ought to get his coat... :D
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Excursion on Wed Sep 28, 2005 10:46 pm
oh crap :lol:
Postby FezzR on Wed Sep 28, 2005 10:47 pm
andymac :
Asad :
Excursion :
Asad : bent
Why i oughta!
Promises, promises hey :wink: Looks like Excursion ought to get his KY coating... :D
FezzR
God Damn Lazy
God Damn Lazy
Postby Excursion on Thu Sep 29, 2005 10:16 pm
I have a set of these for sale if anyones waiting to do the conversion :D
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=114610
Postby Xr_Dub on Fri Sep 30, 2005 12:40 am
Genius work bro :D
Postby Asad on Sat Oct 01, 2005 7:38 pm
Sneak peak
More later.
Asad
Postby krsi on Tue Oct 04, 2005 10:57 am
More pics please :wink: Get a Video up once its running, I'd love to hear the roar of it :D
krsi
Postby Sunil_FiestaRS_16V on Tue Oct 04, 2005 11:08 am
Looking good mate. When you get it all running will have to hook up again would love to hear it and see it go :Q .
Got mine running alot sweeter since last time i saw ya, pulls alot better but hits a slight flat spot at around 5k .
Sunil_FiestaRS_16V
Location: Slough. 2.0 with Raceline head, Raceline cams, T.E Exhaust manifold, and more...
Postby Asad on Tue Oct 04, 2005 11:11 am
:wink:
Was tuning it up last night....runs very sweet! Sounds amazing too!
I installed my Wideband O2 sensor too, made tuning sooo much easier.
Got a RR session booked tomorrow, so hopefully run even better.
As for a video :-
http://media.putfile.com/VIDEO_0000878
Have loads of pics to upload, so will try and do it tonight :D
Asad
Asad
Postby krsi on Tue Oct 04, 2005 11:26 am
Sounds nice. Would sound even better on a drive-by though :wink: Good luck on the RR :)
krsi
Postby chris-fiesta on Tue Oct 04, 2005 1:14 pm
:D sounds mental, good work dude :wink:
chris-fiesta
Postby McNugget on Wed Oct 05, 2005 9:53 am
Real nice work, mate! I love it! :Q
I hope you can get some power out of it! Good luck!
Timo
McNugget
Postby Asad on Wed Oct 05, 2005 8:11 pm
Right lets start from the top!
Here is the stub manifold fitted. I had all the bolts and gasket etc:-
This is with the TBs fitted. No injectors or fuel rail yet:-
You can see my modified throttle linkage. Fits well :-
Long shot:-
My injector rail with the 330cc injectors fitted:-
Brand new injectors:-
Fuel rail is on. You can see the fuel feed pipe at the top:-
And with all the fuel pipes plumbed in, as well as the loom :-
Close up. Wiring is a bit messy at the moment:-
How I made the fuel feed:-
And going to the fuel filter :-
And all on and running! :-
I have since tidied up the loom, fitted an oil breather in a cool location, and tidied up bits and bobs.
I have been tuning it as well, which has been made all the easier with the wideband sensor!
This thing is very loud now! Especially on full throttle! Pops and bangs like crazy, ive even seen it flame!
Will take some more pics of the breather and Wideband controller. Just got the ST170 exhaust manifold to go. And I need to fit an air filter somehow... i have a few ideas!
Asad
Asad
Postby FezzR on Wed Oct 05, 2005 8:35 pm
top bannana mate
looks like you need a new fuel filter :P
FezzR
God Damn Lazy
God Damn Lazy
Postby Zetecfiesta on Wed Oct 05, 2005 8:44 pm
looks sweet as mate, that video is so cool is sounds amazing!
Zetecfiesta
Postby DanS2i on Sat Oct 15, 2005 10:01 am
Where have you fitted the vacuum pipe from the brake servo to?
Dan
DanS2i
Location: Northampton Drives: Like A White Van Man Should!
Postby ant pittaway on Sat Oct 15, 2005 10:37 am
cant get video to work :(
ant pittaway
Postby FezzR on Sat Oct 15, 2005 10:56 am
are you trying to right click save as? if so your doing it wrong its not dowloadable :rolleyes:
works fine other than that
FezzR
God Damn Lazy
God Damn Lazy
Postby FezzR on Sat Oct 15, 2005 10:57 am
DanS2i :Where have you fitted the vacuum pipe from the brake servo to?
Dan
you can see in the pics its the thicker red pipe
FezzR
God Damn Lazy
God Damn Lazy
Postby DanS2i on Sat Oct 15, 2005 11:17 am
Of course it is!! If I had only opened my eyes I would had seen that for my self! :rolleyes:
Dan
DanS2i
Postby Asad on Sat Oct 15, 2005 12:11 pm
Yep, I used the Bike Injector bungs for Vacuum.
Here are some pics of the engine bay pretty much completed (aside from exhaust manifold) :-
FezzR - you can see my breather! Not bad for £40 and it fits nicely too!
Asad
Asad
Postby j_man69 on Sat Oct 15, 2005 12:25 pm
holy bejeeesus what it sound like when its running ??
i need to learn this stuff
project fez has landed !!
j_man69
Postby FezzR on Sat Oct 15, 2005 12:29 pm
tis good, ammuses me you have some seriously clean shiny stuff and some grubby looking standard stuff lol (coolant tank, battery and master cylinder)
i wouldnt have mounted the catch tank on its side, wont catch much if any oil that way
look forward to seeing exhaust manifold
FezzR
God Damn Lazy
God Damn Lazy
Postby Asad on Sat Oct 15, 2005 12:34 pm
Lol i know!
The brake reservoir is leaking, so i'm looking to replace that with an escort one. That should take care of that.
Might keep an eye out for a new water bottle.
Battery will stay as it is! lol
Had a word with Power flow about modifiying the ST170 exhuast manifold I have and they wanted £325! Could get a ready made one for that!
Will see if I can do it myself. If not, ill just buy the correct one.
Cheers for all the comments!
Asad
Asad
Postby FezzR on Sat Oct 15, 2005 12:38 pm
what needs doing to it?
you could get a complete custome made one for £350, they have a habbit of being over priced but they obviously didnt want do it and just quoted you silly money so you dont come back
FezzR
God Damn Lazy
God Damn Lazy
