Megasquirt ECU Fitted!Throttle Bodies Running!New Head!!PG10
Postby alladdin on Thu Jun 01, 2006 10:23 pm
any update on this thread asad ?
alladdin
Postby Max M4X WW on Thu Jun 01, 2006 10:42 pm
Must be working, Flames on the way to fitp were 8) 8)
Would like to see the manifold on though!
Postby purple_fiesta on Fri Jun 02, 2006 11:05 am
looks brill, defo get a filter on them TB's before it goes up in flames though!
6 Point Safety Devices Cage.
purple_fiesta
Postby Asad on Fri Jun 02, 2006 1:48 pm
Cheers guys!
Yeah it does pop alot!
Current updates are - not many! lol
I still have the head to put on, and to sort a less restrictive exhaust manifold.
Im also planning on tidying up some under bonnet wiring and fitting an ITG Megaflow Air Filter.
Once all this is done, hopefully i wont be tempted to do any more engine mods! lol
Im aiming to have it all in before Ford Fair and mapping it up too. Want to do some runs there.
Asad
Asad
Postby ant pittaway on Fri Jun 02, 2006 4:59 pm
top work as always mate! :)
ant pittaway
Postby doggpk on Sun Jun 04, 2006 11:22 pm
love this thread..top work Asad..u so :Q :Q
escort series 1 RS.
Sapph Cossy
doggpk
Postby jim566 on Tue Jun 06, 2006 12:00 am
Even tho i dont drive a fiesta may i congratulate you on your hard work and extremely informative how to. You seem to have made a name for yourself m8 hence i ended up here. TOP JOB :Q
*scuttles off to start work on his mondeo* :D
jim566
Postby CyberMODS on Tue Jun 06, 2006 1:33 am
jim566 :Even tho i dont drive a fiesta may i congratulate you on your hard work and extremely informative how to. You seem to have made a name for yourself m8 hence i ended up here. TOP JOB :Q
now thats a proper 1st post :)
welcome to the board mate :)
CyberMODS
Postby Asad on Tue Jun 06, 2006 7:21 am
Cheers for all the comments!
Was definitely a top project and getting more and more popular!
Let me know if you need a hand :wink:
Asad
Asad
Postby ScottP on Tue Jun 06, 2006 7:41 am
Keep it going ASAD cos I'll need your help in a few years when i get my 1.6 SE, lol
Scott
6 positive comments in trusted traders topic :)
ScottP
Postby escortbreakers.co.uk on Tue Jun 06, 2006 6:00 pm
ive got a 2.0l zetec running megasquirt.
ported and polished head, 2050cc, kent cams and pulleys, 4-2-1 manifold, higher compression, large exhaust system.
badly needs more mapping tho.
also i will be fitting honda fireblade throttle boddies later this year.
Postby krestudon on Sat Jun 17, 2006 3:30 pm
asad; in your megasquirt, do you changed r4 and r7 resistors from the original values to the 27k ohm recomended for ford sensors, and then calibrate with easytherm, or only calibrate with original resistors, or how do you did it?
could you give me your config files for that? and your base maps for a 1.8 everything standard?
thanks
krestudon
Postby DJMattyT on Thu Jun 29, 2006 11:57 am
Hi,
Just change the reisiters to 27k . . noi calibration is needed they will work straight off.
We sell MS ECUs built and setup for Zetecs at http://www..mtechautomotive.co.uk
Have a look . .
Matty
DJMattyT
Postby krestudon on Thu Jun 29, 2006 5:06 pm
thanks i already have an assembled MS, all i need now is a base map to start working
i've been looking at your forums but where the 1.8 base map should be, i cant see nothing.
i've tried registering, but i cant log in...
krestudon
Postby ScottP on Sun Aug 06, 2006 9:03 pm
Any more updates? Any videos?
ScottP
Postby jayrs on Fri Jan 05, 2007 11:09 am
bringing it back.
any updates to this
Postby lucasdemoley on Sun Jan 21, 2007 1:06 am
Any vids? Ive just got myself a set of bodies and read through this entire post, very interesting! No doubt i'll br pestering you with a few pm's trying to set up my ms, if that ok?
cheers!
lucasdemoley
Postby SimonT on Sun Jun 03, 2007 2:12 pm
is this car still about? wondering what stage its at now :)
Too old and too bald.
SimonT
Your car: Fiesta Zetec S TDCi
Postby muz on Sun Jun 03, 2007 2:43 pm
Hurry up and do the manifold, I need to know how to do mine lol.
muz
Postby AndysFatRS on Tue Jun 05, 2007 11:33 pm
my mate has a 2.1zetec running gsxr1000 bodies and everything else imaginable as well as megasquirt.
just a quick video of induction noise while mapping around blackpool
http://www.youtube.com/watch?v=hlfpkJxYP3g
Formally Andyswidefez
Yes, i have a fat RS! lol
BIASmotorsport
AndysFatRS
BIASmotorsport
AndysFatRS
Postby jayrs on Tue Jun 05, 2007 11:48 pm
thats cool, i would love to be able to have my rs mapped like that
Postby Smo on Wed Jun 06, 2007 12:12 am
andyswidefez :my mate has a 2.1zetec running gsxr1000 bodies and everything else imaginable as well as megasquirt.
I'm guessing that gauge on the laptop that's flashing/flicking rapidly is the air/fuel ratio? Is he running narrowband/standard lambda still?
Smo
Postby AndysFatRS on Wed Jun 06, 2007 7:17 pm
yeah thats afr. hes running a narrowband sensor thats knackered, but its not running alpha-n yet so it doesnt reference the sensor. although for mapping purposes there is a wideband mounted in the manifold and the reader hanging from the rear view mirror
BIASmotorsport
AndysFatRS
Previous
