megasquirt
10 posts • Page 1 of 1
megasquirt
as you all know iam trying to make my car 130ps but cannot get one i want to run megasquirt on my car does anyone have any kits for it ie cables already built and have a base map also i know i need a xr2i loom any one got one? and external edis anyone got one? anything else also how long you looking to fit the new management and setting up?
- frostie
Try here:
http://extraefi.co.uk/
What's your engine and loom now? If it's 16V loom or any EFI loom you can use it! One guy sell ECC-IV to MS adapter boards... try to find out on MS forum :
http://www.msefi.com
I'm running MS on my 1800 ZT just fine (10 psi and tunning, don't know how much boost my engine can hold with two gaskets and 1,5 mm decompresiion plate, C/R 7,8:1 , stock pistons, rods ect. no oil cooling jets ). My loom was 1.4 CFi (as previous engine ), just swapped few wires and ready to go... Oh my loom was with external EDIS. Wideband lambda sensor (with controller!) is mandatory, to keep eye on good AFR's!!!
Sorry for my bad english...
- disc
my engine is 105ps 1800 internal loom as its an Si who has base maps on here!
- frostie
- disc
- disc
spike :http://www.mtechautomotive.co.uk/fordV3.html
with this version u dont need external edis
But still need coil pack and some changes in wiring loom.
- disc
Nice ! well ive just got my self some megasquirt kit also what else do i need bar base maps ?
ie, edis controller, xr2i
is that all i need then were can i get these from?
- frostie
also how long will it take to fit and set up on a standard n/a 130ps zetec engine ?
- frostie
disc :spike :http://www.mtechautomotive.co.uk/fordV3.html
version 3 will run directly from the parts on an si, yes u need to make the wiring loom but u get diagrams and labels thats gotta make it easier!
let me know how things go frostie as ill be doing the same as you soon
- spike
