Mike's Azura.... RIP : Member's Gallery - Page 18 | Fiesta Forums
Re: Mike's Azura. NEW STEREO
Postby jonyb4 on Mon Feb 04, 2013 1:38 pm
russ-RST : plus 1.8's are more rev happy than 2ltr
ill second that!
no the bolt pattern on the mk3 rear hub is diffterent
doubt that springs will work, and the cylinders are deffo different
Postby Excursion on Mon Feb 04, 2013 2:27 pm
jonyb4 :
ill second that!
They are wheezy and gutless.
The 2.0 with a proper inlet and management will rev itself to pieces and has far more urgency starting far sooner in the range than a 1.8.
Re: Mike's Azura. Brake drum question!
Postby Michael! on Mon Feb 04, 2013 2:30 pm
Well if building up the 1.8 goes bad I was just going to be a 2.0 and run the cult ecu like you already suggested mark.
ft-com-members-map-vt190192/
Michael!
Postby - Danny Boy - on Mon Feb 04, 2013 3:12 pm
With regards to the bolts, try them and see what happens :)
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Michael! on Mon Feb 04, 2013 7:53 pm
Ok, so the weather was absolutely s**t today - but rather than waste the day I tidied and organised my garage! Took me two hours
As you can see I've striped down the drums! Which was hard, first time I've done them!
I think the shoes are in okay condition?
Only think now is one of them was missing the springs, I'm guessing I'll be able to use the mk3 ones though? AND do the bias' look okay? AND advice for getting the old bushes out?
Michael!
Postby sam-si on Mon Feb 04, 2013 8:05 pm
Michael! :AND do the bias' look okay?
wheres the pictre of the bias then but to be fair you can't see inside them anywy i don't think?!
Michael! :AND advice for getting the old bushes out?
set fire to them with a blow torch when they get going after 5 mins give a wriggle and push with a mettal rod and they fall out.
sam-si
Your car: FORD FIESTA
Re: Mike's Azura. Zetec S Rear Beam!?
Postby - Danny Boy - on Mon Feb 04, 2013 8:14 pm
You call that garage tidy? lol.
The shoes will be fine :)
- Danny Boy -
Postby Michael! on Mon Feb 04, 2013 9:10 pm
- Danny Boy - :You call that garage tidy? lol.
You wanna see what it was like before hand! All the tarp at the back is covering about 500 books my neighbour lumped on me when I did him a 'favour' :/
And Sam it's on one of the pics I'm sure!? Also, planned on heating them up then smashing f**k out of them so I'm was on the right lines hahaha
Michael!
Postby sam-si on Mon Feb 04, 2013 10:16 pm
Michael! :
use bare flame and catch them on fire so it literly melts! still take 5 or ten mins though once alight! and brake bias goes in your brake line system.
sam-si
Postby Rs Adz on Mon Feb 04, 2013 10:20 pm
coming on well when you hoping to have it done
Rs Adz
Your car: xr2i and mk1 fiesta
Postby Michael! on Mon Feb 04, 2013 11:15 pm
Cheers Sam, dose of petrol should do the trick.
Adam I'm not saying hahaha, will be at fitp for sure though - following you down and your 2i ;)
Michael!
Postby jonyb4 on Mon Feb 04, 2013 11:36 pm
Excursion :
jonyb4 :
ill second that!
Dont agree with you there, id take a standard 130 spec 1.8 over a standard 2.0
no urgency to them
Postby - Danny Boy - on Tue Feb 05, 2013 5:53 pm
Have you driven and compared both to come to that conclusion?
- Danny Boy -
Postby jonyb4 on Tue Feb 05, 2013 8:33 pm
owned and driven
Postby jonyb4 on Tue Feb 05, 2013 8:34 pm
not saying either is better or worse, but i just find the sudden spike in power from the 1.8 130 more exciting/thrilling
Edit, thinking about it,, my cams make that power band even more pronounced than 2.0 cams, so im slightly biased
Postby Excursion on Tue Feb 05, 2013 8:55 pm
jonyb4 :owned and driven
You've not had a properly running 2.0 from what I gather? They've always been on a mismatch of 1.8 and 2.0 management parts, and non-HO inlets?
Postby andymac on Tue Feb 05, 2013 9:19 pm
No petrol needed, just a blowlamp and time, give it a minute or two of heat on the rubber, let it catch then a few prods will fetch the centre out, few more minutes burn time and you'll be able to scrape the bulk of the remainder out with a screwdriver, putty knife or what have you.
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Michael! on Tue Feb 05, 2013 9:30 pm
andymac :No petrol needed, just a blowlamp and time, give it a minute or two of heat on the rubber, let it catch then a few prods will fetch the centre out, few more minutes burn time and you'll be able to scrape the bulk of the remainder out with a screwdriver, putty knife or what have you.
Cheers buddy! Hopefully going to get some paint for it and sort the bushes/paint/fit it by the end of the week...
Michael!
Re: Mike's Azura. Brake Drums.
Postby Michael! on Wed Feb 06, 2013 6:15 pm
Anyone have a picture of just the Mk3/3.5 brake drum set of for me? took it apart and cant remember where a couple of bits go and cant be arsed taking the other one off.
thank you.
also, as its my first time - anyone advise me on how to fit the handbrake cable to the zs drums?
Michael!
Postby rsturbonutter on Wed Feb 06, 2013 6:27 pm
It connects up the same way a mk3 one does or did for me but im still unsure which handbrake cable I was sent when ordering a new one as apparently there is a few different types luckily for me it fitted straight up I orderded one listed for an rs turbo off of ebay
rsturbonutter
Your car: Fiesta RS turbo
Postby hb69 on Wed Feb 06, 2013 6:40 pm
If you had anything to do with the fitting, repair, installation of either then its likely they wont be an accurate measure of what each engine is like when its done properly.
hb69
Your car: Fiesta 1.1 LX
Postby Tweek on Wed Feb 06, 2013 8:10 pm
Michael! :also, as its my first time - anyone advise me on how to fit the handbrake cable to the zs drums?
The late mk3.5 handbrake cable should fit. As yours is an N-reg you should have that? Mine was a direct fit and that's N-reg :)
Your car: VW Golf GTD
Postby jonyb4 on Wed Feb 06, 2013 8:27 pm
yeah obviously...
Postby Rs Adz on Wed Feb 06, 2013 8:49 pm
Michael! :Cheers Sam, dose of petrol should do the trick.
yer sure mate hopefully you wont leave me behind :lol:
Rs Adz
Postby Michael! on Wed Feb 06, 2013 9:39 pm
Tweek :
Sweat man! Straight fit will do me hahaha!
And Adam, I doubt I will :) will be in petrol saver mode/careful driving mode as I'd have built the car hahaha
Michael!
Postby Rs Adz on Wed Feb 06, 2013 9:46 pm
Michael! :
Tweek :
:lol: :lol: il be in petrol saving mode properly lol
Rs Adz
Postby Tweek on Wed Feb 06, 2013 10:59 pm
The difference (if it doesn't fit) is the clip that holds the cable to the drum backplate, if it's the wrong cable the clip will fall through the hole.
Postby Michael! on Thu Feb 07, 2013 10:08 am
alright, well ill be at it tomorrow (weather permitting) so we'll find out :D
Michael!
Re: Mike's Azura. Filler/Fiberglass Q's
Postby Michael! on Thu Feb 07, 2013 12:34 pm
i want to fill the bumpstrip in on my standard bumpers as ive already posted on here, but i want to know;
is it best to use filler, then fiberglass over the top of it? or just use filler?
do i use sandpaper to smooth the fiberglass? what grade is best etc
any tips will be appreciated.
Michael!
Postby Gus!! on Thu Feb 07, 2013 12:41 pm
To smooth the filler you need to start with something like p60 and when it is smooth (but a bit rough) move up to some p400 or something to get it a lot smoother :)
Or you could buy my standard bumpers with a chrome strip round them!! :lol: i dont see why you would need fiberglass, filler would do the job :)
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Postby trecoll on Thu Feb 07, 2013 12:43 pm
As the recess is quite deep. You'd be better off removing the strip, then Plastic welding up the recess, then filler over the top of that.
It'll be stronger, so less chance of cracking!
trecoll
Postby Michael! on Thu Feb 07, 2013 1:35 pm
trecoll :As the recess is quite deep. You'd be better off removing the strip, then Plastic welding up the recess, then filler over the top of that.
well on a practice one i filled it and fiberglassed over it and it did crack after a bit...that was my reason for the question... i though the fg might toughen it up but obviously not :(
whats plastic welding?!
Michael!
Postby trecoll on Thu Feb 07, 2013 1:41 pm
Same concept as welding, but with plastic!
DIY way; buy some abs plastic rods off ebay, use an old soldering iron to melt the plastics together and use it as a filler.
Wear a face mask though, cause plastic fumes are killer!
trecoll
Postby Michael! on Thu Feb 07, 2013 1:42 pm
ahh, learn something new everyday. ill look into that as it would probably save money on filler haha.
cheers man :)
Michael!
Postby Tweek on Thu Feb 07, 2013 7:16 pm
I had my MCR splitter smoothed in and held onto the bumper by just filler and 3 rivets lol. It's great strong stuff if applied correctly :D
