MK2 Fiesta Ghia - Low and Slow. *coilovers* : Member's Gallery - Page 6 | Fiesta Forums
Re: MK2 Fiesta Ghia - Low and Slow. *New wheels*
Postby knuckles on Thu Jan 13, 2011 12:11 am
i thought so ....
the rear of mine needs lowering but the 15 inch steel wheels slightly rub when someone sits in the rear of the car over rough bumps.
so was thinking of uprated springs but slightly shorter versions of std spring.
main problem is i space the wheel away to clear the trailing arms but then it gets closer to the inner wheel arch lip. :(
knuckles
Your car: Fiesta Rs turbo
Postby MK2 Jamie on Thu Jan 13, 2011 12:24 am
Have you got an adjustable panhard rod?
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby knuckles on Thu Jan 13, 2011 12:38 am
MK2 Jamie :Have you got an adjustable panhard rod?
nope :(
would that help and if yes how ? :lol:
knuckles
Postby MK2 Jamie on Thu Jan 13, 2011 12:50 am
Im assuming you car is lowered if not then non of this applys haha basically when you lower a MK1/2 the body of the car moves to the left thus making one wheel closer to the inner arch and one further away. Adjustable panhard rods allow you to center the car again.
MK2 Jamie
Postby Dave G fsi on Thu Jan 13, 2011 9:57 pm
Loving the look of this car buddy :Q
Thanks for clearing up about the panhard rod too, was pretty sure this was the case but no-one has ever confirmed it.
Where do you get an adjustable one from?
Im getting coilies for the mk1 soon so will need one soon :)
Dave G fsi
Your car: Mk1 FRS and FRST
Postby jonyb4 on Thu Jan 13, 2011 10:16 pm
am i right in saying my Si has a small panhard rod of sorts?
it has a divice that has a spring built into it, sorta looks liek a panhard connected to the floor/boot pan and the trailing beam
dont know what the heck it is, mind you its only on this becaus eof the abs i think so its likely a sensor :P
Postby knuckles on Thu Jan 13, 2011 10:25 pm
jonyb4 :am i right in saying my Si has a small panhard rod of sorts?
mk3 doesnt have a panhard rod - totally different setup entirely
that thing you describe is the rear brake laden valve :lol: :rolleyes:
thanks for clearing that up jamie :)
i havent lowered the rear yet as it rubs already with standard ride height ...
knuckles
Postby MK2 Jamie on Thu Jan 13, 2011 10:29 pm
knuckles :
I had a quick read through your thread mate. The problem is that the steels you have are 40ET which is way out for a fiesta. You need to look for something with a low 30ET then you'll be fine.
Dave G fsi :Loving the look of this car buddy :Q
Dave il PM you with the details now :D
MK2 Jamie
Postby jonyb4 on Thu Jan 13, 2011 10:33 pm
knuckles :
[/quote]
no need to laugh we all gotta learn
whats that then?
Postby knuckles on Thu Jan 13, 2011 10:35 pm
MK2 Jamie :I had a quick read through your thread mate. The problem is that the steels you have are 40ET which is way out for a fiesta. You need to look for something with a low 30ET then you'll be fine.
the steels are from a mondeo which explains the wider offset
maybe i should get two fiesta 15 inch steels and swap the tyres over on the rear :lol:
knuckles
Postby MK2 Jamie on Thu Jan 13, 2011 10:37 pm
knuckles :
To be honest mate that might be a good idea! haha
MK2 Jamie
Postby jonyb4 on Thu Jan 13, 2011 10:38 pm
MK2 Jamie :
knuckles :
i recommended that a while ago and you said something to disagree with it :(
Postby MK2 Jamie on Thu Jan 13, 2011 10:47 pm
I did?
MK2 Jamie
Postby knuckles on Thu Jan 13, 2011 11:01 pm
MK2 Jamie :I did?
i think he was talking to me :P
knuckles
Postby jonyb4 on Thu Jan 13, 2011 11:05 pm
noo clark
Postby MK2 Jamie on Thu Jan 13, 2011 11:30 pm
I don't remember that ever happening but fair enough.
MK2 Jamie
Postby knuckles on Thu Jan 13, 2011 11:52 pm
im lost too ! :-?
brake laden valve basically applies more braking force to the rear when the car is fully loaded.
most vans have them.
knuckles
Postby EUFez on Fri Jan 14, 2011 12:57 am
Jamie - What other plans do you have in mind for this year? Apart from coilovers? Looking great and can't wait to see it.
EUFez
Postby jonyb4 on Fri Jan 14, 2011 12:58 am
oooh right lol
which mk3's had them? first time ive seen it on one tbh
Postby jayrs on Fri Jan 14, 2011 11:32 am
jonyb4 :oooh right lol
fiestas with ABS had light laden valves mate.
when less weight is in the car less brakeing force/fluid gets to the rears so they dont lock up under hard braking.
when the back is full and the car lowers with the weight, the valves open allowing more flow to the rear brakes for increased braking.
they tend to seize up and leak too, fcuking things (for anyone else interested, all mk3/mk3.5 ones are the same 1.1 to 1.8)
Postby MK2 Jamie on Fri Jan 14, 2011 2:30 pm
EUFez :Jamie - What other plans do you have in mind for this year? Apart from coilovers? Looking great and can't wait to see it.
Ive got a few things planned. Money is a bit tight at the moment as work can only offer me a 20 hour contract but hopefully things will pick up soon and il go onto a 30/35 hour contract, anyway the plans:
Before FITP:
Coilovers
Fit satin black steel bumpers
Roofrack
Summer:
Remove bump strips, get rid of the stone chip and spray were the stone chip was the same gold as the car.
1.8 zetec conversion (maybe, depends on money)
Winter/New year
Have all the front panels on the car replaced to make it minty mint.
MK2 Jamie
Postby dontpannic on Fri Jan 14, 2011 3:30 pm
MK2 Jamie :1.8 zetec conversion (maybe, depends on money)
Why would you downgrade such an immense engine? What are you hoping to achieve by swapping your 7.5l V8 Supercharged Zetec Turbo with Waynes special manifold studs for a 1.8 Zetec?
Postby MK2 Jamie on Fri Jan 14, 2011 3:34 pm
To be honest mate the supercharged turbo'ed V8 zetec is fun but it only does about 3.5mpg so its time for change. Wayne did work wonders on my old RS with his manifold stud trickery, so I'm confident with the new 1.8 in and Waynes magic it will still be a quick car.
MK2 Jamie
Postby dontpannic on Fri Jan 14, 2011 3:39 pm
Aah I see, go for it then, so long as you can beat last years 0-60 time we know it'll be worth it :Q
Postby Chris 2i on Fri Jan 14, 2011 5:46 pm
Dave G fsi :Where do you get an adjustable one from?
got mine off bert from xrtwo.com
http://xrtwo.speedcentral.co.uk/profile.php?mode=viewprofile&u=989
top quality stuff - even though I don't actually need an adjustable one :lol: it was just the quickest and easiest one to source after mine broke.
Chris 2i
Postby Dave G fsi on Fri Jan 14, 2011 8:27 pm
Cool, thanks for that mate :)
Dave G fsi
Postby hb69 on Fri Jan 14, 2011 8:50 pm
I got my panhard rod for my mk1 from dan on xrtwo.com, then polybushed it, didnt cost much either
hb69
Your car: Fiesta 1.1 LX
Postby MK2 Jamie on Fri Jan 14, 2011 8:52 pm
Chris 2i :
Dave that is the same guy I linked you to :)
MK2 Jamie
Postby Dave G fsi on Fri Jan 14, 2011 9:54 pm
Awesome :Q
Will be getting me one of them shortly :D
Dave G fsi
Re: MK2 Fiesta Ghia - Low and Slow. *Exhaust fitted*
Postby rst-steve on Sat Jan 15, 2011 12:04 am
MK2 Jamie :
rst-steve :Liking them Jamie 8)
Defo not keen on the blue tho, you are doing the right thing spraying them :lol:
Thanks mate! Fiesta still tucked up in the garage?
Yep, still under the cover in the garage............ since mid november, starting to forget what it looks like :lol:
Roll on FITP, looking forward to having a good look round your car! :D
rst-steve
Your car: 1990 Fiesta RS Turbo
Postby jonyb4 on Sat Jan 15, 2011 12:45 am
i cant wait for ford fair to see him blow the crowd away with his 1.92 second 0-60 run :lol:
Postby MK2 Jamie on Sat Jan 15, 2011 2:41 am
If I end up doing this engine conversion then I could actually end up doing a decent 0-60 :o ....sub 8s with a good launch I reckon!
MK2 Jamie
Postby jonyb4 on Sat Jan 15, 2011 4:53 pm
aye if its 130 spec ofcourse :)
try and get a tidy air filter and a four branch would easily see under 8 mate :)
Postby black2 on Sat Jan 15, 2011 5:01 pm
MK2 Jamie :If I end up doing this engine conversion then I could actually end up doing a decent 0-60 :o ....sub 8s with a good launch I reckon!
Should get very close to that in standard 1.8 trim, as most 2.0l mk2s get 7 or just below. TBH i woulkd just fit a 2.0l in, its slightly more work but 100% worth it. :D :)
Gareth.
black2
Postby MK2 Jamie on Sat Jan 15, 2011 5:12 pm
jonyb4 :aye if its 130 spec ofcourse :)
Yea should be 130 spec hopefully, even if its still at 115 it'll go well. Il be sticking a four brand on it but most probably and using a standard drilled airbox. Im not a fan of cone filters....probably just go for a k&n panel filter. My old RS ran a 8.1 0-60 with standard air box and a mongoose exhaust being the only modification which I didnt think was too bad considering the clutch was on its way out.
black2 :
Should get very close to that in standard 1.8 trim, as most 2.0l mk2s get 7 or just below. TBH i would just fit a 2.0l in, its slightly more work but 100% worth it. :D :)
Gareth.
It had crossed my mind but there seems to be mixed feedback on them. A lot of people seem to say they dont rev as freely as the 1.8 does? Saying that the extra 21 bhp over a 115 spec engine would be nice.
MK2 Jamie
