MK2 Fiesta Ghia - Low and Slow. *coilovers*
- hb69
- Your car: Fiesta 1.1 LX
Re: MK2 Fiesta Ghia - Low and Slow. *Burton Power package*
omg !
a multiple piece cvh sump gasket !
good luck with that ... tenner says you throw it away and get a one piece rubber gasket instead.
- knuckles
- Your car: Fiesta Rs turbo
I'm not looking forward to fitting that now you've said that
- MK2 Jamie
knuckles :omg !
R5 uses em..they a complete toss bag,Takes a mountain of sealer to make em seal proppa
see this is why we respect and use Rubber..Interprate that as you wish..
- Fraggle
MK2 Jamie ::( I'm not looking forward to fitting that now you've said that
send it back and get a proper rubber one.
ford replaced the old type cork and half moons with the one piece gasket for a reason
also for the sake of £45 get a new sump. i bet the old one is rusted or has been overtightened at some point in its life. making it near on imposible to get a even seal on the new gasket without s**t loads of sealer.
My Rs i built and sold went through 2 sump gaskets then needed a new sump.
Check the metal inserts for its straightness and check to see if the matting surface of the sump is straight too. If its distorted ,,, chuck it !
- knuckles
- MK2 Jamie
Re: MK2 Fiesta Ghia - Low and Slow. *Engine progress*
did u sort the sump gasket ?
- knuckles
Used the multi piece gasket. Fingers crossed
- MK2 Jamie
MK2 Jamie :Used the multi piece gasket. Fingers crossed
im assuming u did it upright on the stand ?
did you use sealer on the half moons and on the flat edges where the gaskets meet ?
- knuckles
I covered every part of it in a ton of sealer
- MK2 Jamie
MK2 Jamie :I covered every part of it in a ton of sealer
good man
- knuckles
- MK2 Jamie
Re: MK2 Fiesta Ghia - Low and Slow. *Carb arrived*
this will be mint with the cvh , prefer them over zetecs or any other engine on mk1's and mk2's
- jakerowles
- Your car: Fiesta
I would have liked a zetec but I just can't afford it at the moment. I do kinda prefer them over zetecs though in regards to how they look in the engine bay....oh and how cheap they are
- MK2 Jamie
MK2 Jamie :I would have liked a zetec but I just can't afford it at the moment. I do kinda prefer them over zetecs though in regards to how they look in the engine bay....oh and how cheap they are
i want a 1.4 for my mk3 could of had one for £50 with all ancilorys and gearbox but dint have the money at the time
- jakerowles
- Your car: Fiesta
You so should of got some twin 40's and a s/s fanimould for it
- russ-RST
- Your car: fiesta rs turbo
All in good time I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
- MK2 Jamie
MK2 Jamie :All in good time I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
Not long 'till the 0-60 shakedown!
- bakewell001
bakewell001 :MK2 Jamie :All in good time I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
Should be interesting to see what I get this year. Low 8s I reckon.
- MK2 Jamie
MK2 Jamie :bakewell001 :MK2 Jamie :All in good time I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
Low 8's? You're really underestimating your skills, Jamie.
- dontpannic
Haha! I don't wanna sound like another Jony and make outrageous claims.
- MK2 Jamie
MK2 Jamie :Haha! I don't wanna sound like another Jony and make outrageous claims.
we no yr only messing though
- Minstral
- Your car: *
Sometimes I'm being a tiny bit serious. Rung HIC today, £60 extra for the engine conversion
- MK2 Jamie
- Smo
8's might be realistic with that setup
- hb69
Follow something fast off the lights, that'll get you your ballpark figure.
- Tweek
- Your car: VW Golf GTD
Tweek :Follow something fast off the lights, that'll get you your ballpark figure.
Most accurate method, think they might be using something similar to do the timing at ff this year
- hb69
make sure its a BMW perhaps an M3...
- Michael!
hb69 :8's might be realistic with that setup
Yea, with the car stripped out i'd expect 8's. Anything over that and I'll be disappointed.
- MK2 Jamie
Who cares what you get, the car will still look good doing it's business
And the longer you take, the more showtime you get
- Smo
Yea last year I had over 12 seconds of show time
- MK2 Jamie
should just go for a cruise up the strip
- Minstral
- Your car: *
You should ghost ride it up the strip.
- fiend
fiend :You should ghost ride it up the strip.
Not sure how keen the ford fair organizers would be on that.
- MK2 Jamie
if you were game im sure they would be
- Michael!
