MK2 Fiesta Ghia - Low and Slow. *coilovers*
Re: MK2 Fiesta Ghia - Low and Slow. *Head off engine*
when you hoping to fit it?
- Minstral
- Your car: *
I'd like to have it in before ford fair, we'll see. Don't surprised if its not in by then though
- MK2 Jamie
Get on it. Should be a pretty much straight fit
- hb69
- Your car: Fiesta 1.1 LX
To fit it I need an xr2 gearbox cradle, gear linkage, tie bars and engine mount.
- MK2 Jamie
Nah keep the 4 speed, was an optional extra anyway wasnt it
- hb69
I am tempted to keep it 4 speed...
- MK2 Jamie
MK2 Jamie :To fit it I need an xr2 gearbox cradle, gear linkage, tie bars and engine mount.
you dont need to swap craddle to fit the 5 speed box. mine runs a 1.1 cradle.
You only need a cvh Right hand xr2 front tie bar to clear the cvh alternator and of course a cvh engine mount.
The left tie bar fits ok with 5 speed box
You need to get a 5 speed mk2 complete linkage and fit that or ....
get a mk3 5 speed gear linkage and remove the stabilizer bar from it then fit the stabilizer bar from the mk2 4 speed selector to the mk3 linkage. This is what i needed to do as the mk3 item wouldnt fit straight on.
Make sence ?
- knuckles
- Your car: Fiesta Rs turbo
Linkage makes sense. Ive heard of using a mk3 linkage before. What did you do on the gearbox cradle to fit the 5 speed box?
- MK2 Jamie
i just used the mk2 gearbox cradle brackets to mount the gearbox to the cradle using mk2 gearbox mounts.
i was also told a mk3 gear linkage is a straight fit but then worked out the stabilizer bar is too long for the chasis.
- knuckles
Easy as that? sweet. That will save me some money
- MK2 Jamie
MK2 Jamie :Easy as that? sweet. That will save me some money
someone told me on xrtwo.com that i needed both tie bars and the xr2 gearbox craddle to fit a 5 speed box
[ERRR] a load of poop
- knuckles
yay do it for FF and go on track! and the 60 run you really can brag this year
- MK2 Jamie
Re: MK2 Fiesta Ghia - Low and Slow. *Bought another MK2*
pitty to see a mk2 die
Should have that fired up in a morning.
Ideal that the car is a late mk2 so it already has electronic ignition on it, rather than old school points. All you need to do now is extend the little black electrical plug that goes to the dizzy, (as the dizzy is the other end on the cvh) and your away.
Gareth.
P.s that mk2 your breaking / scrapping, theres no chance you could let me know if the passenger side front indicator bulb holder is ok and working is there? if all is well can i buy it off you please?
Gareth.
- black2
you know it would be smart to use this other mk2 as a run around while you do the conversion, then last minute take the box off it and get the rest done quickly
Black, I'll check tomorrow and PM you
- MK2 Jamie
MK2 Jamie :Black, I'll check tomorrow and PM you
Ok cheers
Gareth.
- black2
jonyb4 :you know it would be smart to use this other mk2 as a run around while you do the conversion, then last minute take the box off it and get the rest done quickly
Can't afford to insure it and tax it at the end of the month.
- MK2 Jamie
- MK2 Jamie
Swap the window seals over to get rid of the chrome
- hb69
I'm a fan of the chrome so its staying.
- MK2 Jamie
Nice Jamie............. nice!
lol sounds a nice project and i bet you paid bugger all for that Mk2, defo worth it to get the box!
- rst-steve
- Your car: 1990 Fiesta RS Turbo
MK2 Jamie ::o I'm a fan of the chrome so its staying.
definatly keep it
- Minstral
- Your car: *
hb69 :Swap the window seals over to get rid of the chrome
it wouldnt be a ghia if it had no chrome.
- knuckles
knuckles :hb69 :Swap the window seals over to get rid of the chrome
I got rid of as much as i could on my mk1
- hb69
hb69 :knuckles :hb69 :Swap the window seals over to get rid of the chrome
Its the only way.
- Ratspeed
Chrome trim FTW
- Tweek
- Your car: VW Golf GTD
id ditch the stickers though
The Fat Fake XR2i
- 3lward
3lward :id ditch the stickers though
They are part of an fitp tradition. Would probably kick off
- hb69
As Henry said it's tradition. He'll kick off if I remove them and you don't wanna see that.
- MK2 Jamie
MK2 Jamie :3lward :id ditch the stickers though
Last time Henry kicked off he caused an earthquake in Japan. We don't want that happening again
- dontpannic
keep the chrome, i like this car, looks pretty awesome with the roof rack too!
- Michael!
dontpannic :MK2 Jamie :3lward :id ditch the stickers though
That explains Folkestone! It all makes sense now.
- Smo
- MK2 Jamie
