MK2 Fiesta Ghia - Low and Slow. *coilovers* : Member's Gallery - Page 11 | Fiesta Forums
Re: MK2 Fiesta Ghia - Low and Slow. *Burton Power package*
Postby hb69 on Mon Jun 13, 2011 10:37 pm
Nice package
hb69
Your car: Fiesta 1.1 LX
Postby knuckles on Mon Jun 13, 2011 10:44 pm
omg !
a multiple piece cvh sump gasket !
good luck with that ... tenner says you throw it away and get a one piece rubber gasket instead. :wink:
knuckles
Your car: Fiesta Rs turbo
Postby MK2 Jamie on Mon Jun 13, 2011 10:48 pm
:( I'm not looking forward to fitting that now you've said that
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Postby Fraggle on Mon Jun 13, 2011 10:48 pm
knuckles :omg !
:lol: :lol:
R5 uses em..they a complete toss bag,Takes a mountain of sealer to make em seal proppa :rolleyes:
see this is why we respect and use Rubber..Interprate that as you wish..
Fraggle
Postby knuckles on Mon Jun 13, 2011 10:54 pm
MK2 Jamie ::( I'm not looking forward to fitting that now you've said that
send it back and get a proper rubber one.
ford replaced the old type cork and half moons with the one piece gasket for a reason :)
also for the sake of £45 get a new sump. i bet the old one is rusted or has been overtightened at some point in its life. making it near on imposible to get a even seal on the new gasket without s**t loads of sealer.
My Rs i built and sold went through 2 sump gaskets then needed a new sump.
Check the metal inserts for its straightness and check to see if the matting surface of the sump is straight too. If its distorted ,,, chuck it ! :Q
knuckles
Postby MK2 Jamie on Tue Jun 21, 2011 8:21 pm
The engine is back together now and timed up. Need to put a gasket on the cam belt cover. On the look out for carb and manifold then once those are sourced the engine can be put in the car hopefully before Ford Fair.
MK2 Jamie
Re: MK2 Fiesta Ghia - Low and Slow. *Engine progress*
Postby knuckles on Tue Jun 21, 2011 8:24 pm
did u sort the sump gasket ?
knuckles
Postby MK2 Jamie on Tue Jun 21, 2011 8:29 pm
Used the multi piece gasket. Fingers crossed :lol:
MK2 Jamie
Postby knuckles on Tue Jun 21, 2011 8:43 pm
MK2 Jamie :Used the multi piece gasket. Fingers crossed :lol:
im assuming u did it upright on the stand ?
did you use sealer on the half moons and on the flat edges where the gaskets meet ?
knuckles
Postby MK2 Jamie on Tue Jun 21, 2011 11:22 pm
I covered every part of it in a ton of sealer :D :D
MK2 Jamie
Postby knuckles on Tue Jun 21, 2011 11:22 pm
MK2 Jamie :I covered every part of it in a ton of sealer :D :D
good man :D
knuckles
Postby MK2 Jamie on Tue Jul 05, 2011 10:24 pm
Carb (32/24 Weber DFT off an XR challenger XR2) came today so I got it fitted, also fitted the exhaust manifold. Getting a dizzy this week then all I need is ht leads and a couple of hoses.
MK2 Jamie
Re: MK2 Fiesta Ghia - Low and Slow. *Carb arrived*
Postby jakerowles on Tue Jul 05, 2011 10:36 pm
this will be mint with the cvh , prefer them over zetecs or any other engine on mk1's and mk2's
jakerowles
Your car: Fiesta
Postby MK2 Jamie on Tue Jul 05, 2011 10:39 pm
I would have liked a zetec but I just can't afford it at the moment. I do kinda prefer them over zetecs though in regards to how they look in the engine bay....oh and how cheap they are :D
MK2 Jamie
Postby jakerowles on Tue Jul 05, 2011 10:41 pm
MK2 Jamie :I would have liked a zetec but I just can't afford it at the moment. I do kinda prefer them over zetecs though in regards to how they look in the engine bay....oh and how cheap they are :D
i want a 1.4 for my mk3 could of had one for £50 with all ancilorys and gearbox but dint have the money at the time :cry:
jakerowles
Your car: Fiesta
Postby russ-RST on Tue Jul 05, 2011 11:35 pm
You so should of got some twin 40's and a s/s fanimould for it :Q :devil: :aviator: :wink:
russ-RST
Your car: fiesta rs turbo
Postby MK2 Jamie on Wed Jul 06, 2011 7:58 am
All in good time :wink: I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
MK2 Jamie
Postby bakewell001 on Wed Jul 06, 2011 9:12 am
MK2 Jamie :All in good time :wink: I'm rushing to get it in for Ford Fair. The manifold will be ditched asap after FF for a 4-2-1 and il source some 40s nearer the end of the summer. The carb I've got is the best oem carb for the cvh engine.
Not long 'till the 0-60 shakedown! :aviator:
bakewell001
Postby MK2 Jamie on Wed Jul 06, 2011 10:05 am
bakewell001 :
Should be interesting to see what I get this year. Low 8s I reckon.
MK2 Jamie
Postby dontpannic on Wed Jul 06, 2011 10:43 am
MK2 Jamie :
bakewell001 :
Low 8's? You're really underestimating your skills, Jamie.
Postby MK2 Jamie on Wed Jul 06, 2011 10:56 am
Haha! I don't wanna sound like another Jony and make outrageous claims.
MK2 Jamie
Postby Minstral on Wed Jul 06, 2011 12:31 pm
MK2 Jamie :Haha! I don't wanna sound like another Jony and make outrageous claims.
we no yr only messing though :lol:
Minstral
Your car: *
Postby MK2 Jamie on Wed Jul 06, 2011 5:01 pm
Sometimes I'm being a tiny bit serious. Rung HIC today, £60 extra for the engine conversion :aviator:
MK2 Jamie
Postby Smo on Wed Jul 06, 2011 5:55 pm
They do look after you, HIC :)
Smo
Postby hb69 on Fri Jul 08, 2011 12:08 am
8's might be realistic with that setup
hb69
Postby Tweek on Fri Jul 08, 2011 12:11 am
Follow something fast off the lights, that'll get you your ballpark figure.
Your car: VW Golf GTD
Postby hb69 on Fri Jul 08, 2011 11:20 am
Tweek :Follow something fast off the lights, that'll get you your ballpark figure.
Most accurate method, think they might be using something similar to do the timing at ff this year
hb69
Postby Michael! on Fri Jul 08, 2011 11:33 am
make sure its a BMW perhaps an M3...
ft-com-members-map-vt190192/
Michael!
Postby MK2 Jamie on Fri Jul 08, 2011 2:06 pm
hb69 :8's might be realistic with that setup
Yea, with the car stripped out i'd expect 8's. Anything over that and I'll be disappointed.
MK2 Jamie
Postby Smo on Sat Jul 09, 2011 11:26 pm
Who cares what you get, the car will still look good doing it's business :aviator:
And the longer you take, the more showtime you get :D
Smo
Postby MK2 Jamie on Sun Jul 10, 2011 12:39 pm
Yea last year I had over 12 seconds of show time :lol:
MK2 Jamie
Postby Minstral on Sun Jul 10, 2011 5:35 pm
should just go for a cruise up the strip
Minstral
Your car: *
Postby fiend on Mon Jul 11, 2011 12:28 pm
You should ghost ride it up the strip.
fiend
Postby MK2 Jamie on Mon Jul 11, 2011 8:37 pm
fiend :You should ghost ride it up the strip.
Not sure how keen the ford fair organizers would be on that.
MK2 Jamie
Postby Michael! on Mon Jul 11, 2011 9:15 pm
if you were game im sure they would be
Michael!
