Mk3 1990 fiesta ghia!! Bad news, maybe the end!!
Re: Mk3 1990 fiesta ghia!! Spot lights fitted!!
Postby Christina on Tue Mar 04, 2014 7:00 pm
Yeah one of mine is f**cked too, I've had to use tape as well as the screws. One of them is only in there for show :P
Christina
Your car: '90 Fiesta Popular Plus Mk3
Postby Gus!! on Wed Mar 05, 2014 2:26 pm
It didn't help that some penis had riveted the plates on before I had it, might try and get some like the ones you got for yours the other day!!
Gus!!
Your car: Mk3 Fiesta ghia 1.1!!
Postby Christina on Wed Mar 05, 2014 4:02 pm
They do look good, should look good with your reg too.
Christina
Postby Gus!! on Mon Mar 10, 2014 9:16 pm
As the weather was lovely today, I sorted the front bumper, straightened the number plate, cleaned and polished the car and also replaced the air filter!! Then went for a drive in the sun!!
I cleaned behind the front bumper and I was actually surprised how good it is
The old air filter was pretty old!!
One beautifully straight number plate!!
And some other pictures too!!
Gus!!
Re: Mk3 1990 fiesta ghia!! Random pictures!!
Postby Smo on Mon Mar 10, 2014 9:36 pm
I think it's now time for some of these steels and trims (from earlier in your thread, obviously!):
Smo
Postby Tweek on Mon Mar 10, 2014 10:02 pm
Something tells me it'd suit those 50p shaped XR2i alloys lol
Your car: VW Golf GTD
Postby Smo on Mon Mar 10, 2014 10:05 pm
Well I thought that, but it's quite common and I think the banded steels and trims would look a bit cooler :)
Smo
Postby Gus!! on Mon Mar 10, 2014 10:17 pm
Remember the white pots I had at ford fair Wayne?? Well I might have just aquired them, also an rs accessory kit is in the pipeline!!
Gus!!
Postby willowandmikey on Mon Mar 10, 2014 10:18 pm
I think the trims look the dogs !!
willowandmikey
Your car: ford fiesta xr2i 8V
Postby Gus!! on Wed Mar 12, 2014 5:25 pm
Those wheels with trims are cool, in fact, that whole 1.6s is bloody cool!!
Gus!!
Postby fastfezz on Mon Mar 17, 2014 10:14 pm
I just love this car :lol: and yeah them banded steels would finish your car off perfect
fastfezz
Postby Gus!! on Tue Mar 25, 2014 3:14 pm
Cheers mate, got some white pepperpots yesterday, looks a lot cleaner now :)
Gus!!
Postby dontpannic on Tue Mar 25, 2014 3:16 pm
Black rubber spoiler next!
Postby Gus!! on Tue Mar 25, 2014 5:11 pm
I already have one in the garage, need to find something to stick it on with, if I'm getting this rs accessory kit I might as well well and do it when I get the skirts!! :)
Gus!!
Re: Mk3 1990 fiesta ghia!! Spax and rs goodies :)
Postby Gus!! on Fri Apr 18, 2014 4:28 pm
Hello people. Made some progress on the fiesta today, finally put my spax shocks on, had to give them a quick coat of black as they looked a bit rough tbh. Had a bit of a drive with them, the car no longer feels like everything is loose, I shall be 'testing' them on a long drive in the new forest shortly!! I also invested in an rs accessory kit, I have attached the front and rear bumper and now all I need to do is get some adhesive type substance to do the skirts!! And the tip of the exhaust now looks gay :(
Anyways here's a few pictures!!
Gus!!
Postby hb69 on Fri Apr 18, 2014 4:44 pm
Looks good this, any plans for an engine swap?
hb69
Your car: Fiesta 1.1 LX
Postby Gus!! on Fri Apr 18, 2014 7:03 pm
I do have plans, I just hope they happen :) I was surprised at how much difference the shocks made!!
Gus!!
Postby dontpannic on Fri Apr 18, 2014 7:20 pm
I just put new shocks on the saxo and you're right - total difference, it's amazing!
This is a good looking car. I approve.
Postby hb69 on Fri Apr 18, 2014 7:41 pm
Burmans approval makes it all worth it I bet :aviator:
What are these engine plans you speak of?
hb69
Postby Gus!! on Fri Apr 18, 2014 7:45 pm
I was thinking Zetec but after having a conversation with a mate the other day I might go cvh on a carb!! Birman has had a lot of experience with fiestas so his approval can only be a good thing :)
Gus!!
Postby dontpannic on Fri Apr 18, 2014 8:51 pm
Gus!! :I was thinking Zetec but after having a conversation with a mate the other day I might go cvh on a carb!! Birman has had a lot of experience with fiestas so his approval can only be a good thing :)
Not as much as you'd think!
Postby Gus!! on Sat Apr 19, 2014 1:29 am
Well you have had more experience than me!! Everything I do to this car I love it more!! The problem is, where I use the car daily it's hard to find time to do things to it, due to lack of tools I have to borrow my dads usually too!! :(
Gus!!
Re: Mk3 1990 fiesta ghia!! Bad news, maybe the end!!
Postby Gus!! on Sat May 17, 2014 10:24 pm
On the way back from Brighton today, some dozy Bic™ in a mazda 6 rear ended me at some lights, which pushed me into the car in front!! The front of my car isn't too bad, just a light and bumper, the back however has creased the boot floor, I also can't shut the boot, I'm not sure if it's possible to pull the rear panel out :(
Gus!!
Postby Smo on Sun May 18, 2014 2:20 am
Ah, no way :(
You could probably straighten it all out a bit so it looks OK and the lid shuts, but you'll probably find it nightmare to get right. I had an Avensis slide into the back of me in the snow once and it didn't look too bad. I made the mistake of opening the boot and not being able to shut it again! I used a jack and a hydraulic ram to straighten it out and was able to shut the boot again, but I was never going to get the boot floor flat.
Has the impact damaged either of the chassis rails?
Smo
Postby Smo on Sun May 18, 2014 2:26 am
You'll have to get some better photos, may be with the back seats down so you can see more of the boot area as a whole from a bigger distance. It's hard to tell, but it looks like it was quite a whack to tear that rear panel?
Smo
Postby Tweek on Sun May 18, 2014 8:53 am
Ah man that sucks :( :'(
Postby Gus!! on Sun May 18, 2014 11:08 am
Chassis rail on drivers side looks bent and so does the inner arch!! Also the door shut has moved forward slightly I think!!
Gus!!
Postby Excursion on Mon May 19, 2014 12:33 pm
Cut two holes along the rear of the boot, below the chassis section to which the boot striker is bolted to. Feed through two tow ropes and use another car to yank out the damage. Take it steady. If you can get the rear door shut correct the rest is an easy repair, or may not even be required if you can put up with a few creases inside the boot.
Postby Gus!! on Tue May 20, 2014 10:12 pm
Looks like it's going through insurance. 100% it's gonna get written off.
Gus!!
Postby dontpannic on Wed May 21, 2014 11:54 am
Buy it back and do what Mark said. That's what I did with my MK5 when a lady in a Ka went into the back of me, although I didn't use another car, I tied a rope around a tree then into the boot. Worked a charm :)
Postby Gus!! on Wed May 21, 2014 6:32 pm
The car is twisted, the rear axle has moved over about 2 inches, so I'd say she's f**cked :(
The current plan is to see how much insurance pay out and then get another one!! And sell all the remaining bits of this one hopefully!!
Gus!!
Previous
