Mk3.5 Fiesta Zetec Turbo Azura - DEPOSIT TAKEN
10 posts • Page 1 of 1
This is going to be a long post, so apologies in advance but I've owned this car for for around 8 years and even though I have only covered around 2500 miles I still have a lot to say about it! A brief history..
* I bought the car in 2008 with 51k miles, two previous owners and a clean shell with a couple of rust spots in the usual places.
* In October 2009 the car went to Hine Motors (Ford) in Shaftesbury (after they were recommended by Shaun/CarbonBoy on here) for some bodywork repairs to be carried out. I have photos of the car before before and during this work.
* Over the next few years (!) the car evolved from what you see below..
PROJECT THREAD HERE: m4x-ww-zt-project-for-sale-breaking-soon-vt181835/
to this..
The full spec of the car as it stands is as follows..
1995 Ford Fiesta 'Azura'
Originally a 1.1 8v
NON PATS Mk3.5 wiring loom
Engine..
Ian Howel built 2.0 16v Zetec-E
Focus RS Mahle forged pistons
Focus RS rods, ARP big end bolts
Ahmed Bayjoo spec injectors
Hybrid T3 Turbo, 2.5 bar MAP sensor
Uprated Escort Cosworth fuel pump
Cosworth 4x4 fuel pressure regulator
Forge Front Mount Intercooler
K&N Air Filter
3" Bore Stainless Steel Exhaust
Roose Motorsport Water & Boost Hoses
Bailey oil breather/separator
Vibratechnics Engine Mount
Power Assisted Steering
(The engine has probably been built 10 years now, but is a really good one! It runs sweet as a nut and Grove Garage have commented various times to Mikee who has it before me about how good it was)
Transmission..
CTS Stage 2+ Gearbox, Quaife ATB Diff
AP 4-Paddle Clutch, Standard Cover Plate
Vibratechnics Mounts
Suspension..
GAZ Coilovers
IH Rose Jointed & Camber Adjustable Lower Arms
FRST Anti Roll Bar & Crossmember
Mk5 Fiesta Zetec S Rear Beam
Powerflex bushes on ARB & Rear Beam
OMP Rear Strut Brace
Brakes..
280mm Fiesta ST Front Brake Setup
Mk5 Fiesta Zetec S Rear Drums
Wheels & Tyres..
Team Dynamics Pro Race 1.2's
195/45/15 Toyo T1R's
Exterior..
RS Accessory Rear Lights
Smoked Side Repeaters
Green Tint Glass
Interior..
Fiesta RS Turbo Recaro Seats
Fiesta RS1800 Doorcards
Fiesta RS1800 Leather Steering Wheel
Ford Leather Gear Knob & Gaiter
STACK Oil Pressure, Temp & Boost Gauges
If you do not know me, I am particularly fussy with my cars in so this is the main reason it took so long to get this far! The car is not what I would call 100% finished, but it was MOT'd with one advisory in August last year and I have been using the car occasionally (Approx 1000 miles) since. Being very critical, the following things need doing on the car (in order of what I deem important, top to bottom)
* The Cooling system needs re-plumbing, it is currently routed like a CVH with but with no thermostat in place. With a stat the coolant foams up. (I copied the cooling system from photos of the engine in its previous home, which is obviously wrong!)
* Set-up/map by Ahmed at Grove Garage, the car ECU has been lived mapped but I know the car is running lean.
* This may show up that the radiator is too small/not good enough. It is a standard FRST size in alloy, but I don't think its the best.
* The clutch biting point tends to move, IE sometimes it is low and sometimes it is high. A press of the pedal can move it back to where it should be, so I assume it is pedal related. I didn't get round to looking at it.
* The exhaust needs a hanger fabricating at the front, it is currently held up by a ratchet strap (my biggest bodge, apologies!)
* The fuel gauge does not work, the float may be stuck on the 1.1 swirl pot or it may be broken.
* The rev counter doesn't read correctly, its probably the wrong one or needs adjusting
* The steering feels stiffer to turn one way than the other, I'm not sure why but I doubt the rack is at fault as it is a very low mileage item which I got from MWStewart.
This list is probably not conclusive, but as I said - I'm being critical, the car is perfectly drivable.
I'm rambling now, but if you got this far you must be slightly interested and you will want to know what its going to cost you! Obviously I've spent thousands on the car and want to get as much of this back as possible, preferably without breaking it.
To give an idea, the car cost me £950, the bodywork was £1000 and the engine package cost me £2000. Given the value of the parts on the car, I am currently looking for (DEPOSIT TAKEN) for the car. I am very open to discussion and if you want to swap and change or remove parts from the car (to an extent!) something could be arranged.
This is a big one for me, but the time has come to move it on! If you are interested or have any questions please get in touch via the PM system on here.
Thanks, Max
Re: Mk3.5 Fiesta Zetec Turbo Azura FOR SALE
Good luck, Max. Your cars are always exceptionally clean.
Glwts max looks lovely
- SEG1
Re: Mk3.5 Fiesta Zetec Turbo Azura - DEPOSIT TAKEN
DEPOSIT TAKEN
Glad to see this is going to live on instead of being broken up
- Tweek
- Your car: VW Golf GTD
looking forward to having a closer look at it when the new owner has it
- FRSJON
Lovely looking car
- luca
well who ever is buying it must have a passion for red fiesta's as the paint work on this is one of the best
- FRSJON
Great result.
This most be one of the fastest as it's red too! Must add some value
14.41 1/4 mile @ 96.95mph 0.088s reaction
- Dave_B
