Mk3.5 hubs and shocks on mk3 questions
Postby Rsmark86 on Mon Sep 16, 2013 9:16 am
Hi some one has fitted mk3.5 shocks on my mk3 and forced the mk3 hub over the end
Can I fit mk3.5 hubs too suit the shocks as they are mint and I have a mint pair of hubs with long stud conversion already done?
I'm hoping I don't have to change lower arms as I have some rose jointed looking ones too fit?
Rsmark86
Your car: Fiesta rst zetec turbo
Re: Mk3.5 hubs and shocks on mk3 questions
Postby jayrs on Mon Sep 16, 2013 6:14 pm
Should be fine tbh mate, the difference in size on the ball joint end is minimum, if you fit them and your not happy with how they are change the ball joints, I assume being rise jointed arms the ball joint is bolted on?
Postby Rsmark86 on Mon Sep 16, 2013 7:02 pm
It's got pressed in custom bushes/ joints
But I could change the ball joints if needed
Well I'm going to stick some new bearing in and get some nice spacers done for my 4x4 brakes
And get them fitted up
Cheers mate
Rsmark86
Postby jayrs on Mon Sep 16, 2013 7:11 pm
Mo worries dude, you might not need to change the ball joints, but thought I would say just in case
Postby Rsmark86 on Mon Sep 16, 2013 10:03 pm
thats cool, thanks for the help, i read somewhere someone saying you needed everything from a mk3 including lower arms, track rods, shocks the lot lol
so if its just ball joints im happy with that, saves me looking for more mk3 hubs and having to restud them
i need to find some sort of kit or way of spacing the rear drums/hubs 10mm like the axle widering kits used on later fiesta's, as im having to space the fronts to clear shocks and think the rears need 10mm where as the fronts need 5mm just to look/sit right for my liking
Rsmark86
Postby jayrs on Mon Sep 16, 2013 11:17 pm
Rsmark86 :thats cool, thanks for the help, i read somewhere someone saying you needed everything from a mk3 including lower arms, track rods, shocks the lot lol
There's ways round them things.
Spacing the stub axle off is the best bet tbh mate, you could buy a bit of 10mm alloy and make ya own up, or get the kit for the later one and open the holes out to suit
Postby Rsmark86 on Tue Sep 17, 2013 1:20 am
im going to see a fabricator tomorrow thats cheap as chips and very skilled so might just ask him to machince some up and sort the correct bolts ect too suit
i think 5mm front and 10mm rear will sit really nice but i dont like 10mm wheel spacers i would rather space the rear properly
otherwise im looking at 15mm hubcentric ones but the offset might be abit much with that on the front :x
Rsmark86
Postby jayrs on Tue Sep 17, 2013 6:39 am
Depending how 'rough' you want them, a bit of 10mm alloy plate bandsawn roughly to shape, burrs filed off and 4 holes drilled in each should be fairly cheap to be far and wouldn't taken them long to do.
And I know what ya mean, I'm not a fan of std big wheel spacers, and over the years I've seen some shocking things lol
Postby Rsmark86 on Tue Sep 17, 2013 7:02 pm
A member on here has come forward and said he has a kit he had made he will sell
I just need some rear top mounts and I have everything
Rsmark86
Postby jayrs on Wed Sep 18, 2013 7:07 am
Rear top mounts? As in shock fixing?
Postby Rsmark86 on Wed Sep 18, 2013 7:52 am
Yeh just everything that sits on the top of the spring, except the bit inside the car where the bolt goes through?
Rsmark86
Postby jayrs on Wed Sep 18, 2013 8:26 am
So just the rubber bit then?
Postby Rsmark86 on Wed Sep 18, 2013 11:05 am
Well every thing that's under the wheel arch on top of the spring?
Rsmark86
Postby jayrs on Wed Sep 18, 2013 3:04 pm
Ah that would be the rubber bit and top cup where the shock bolts in and the 2 studs stick up through the rear turret
Postby Rsmark86 on Wed Sep 18, 2013 10:03 pm
Yeh I need those as I'm selling the rear coilovers and fitting nearly new gmax kit but they are missing?
Rsmark86
Postby jayrs on Thu Sep 19, 2013 5:15 pm
Your get some easy there the same in all mk3
Postby Rsmark86 on Fri Sep 20, 2013 11:03 am
Yeh, I also need to get my gotech tested but that's another story
Rsmark86
Postby mikeymikeyp on Fri Sep 20, 2013 6:57 pm
Are you taking coilys off and putting gmax shoks back on
mikeymikeyp
Postby Rsmark86 on Sat Sep 21, 2013 9:32 am
Yeh lol
I only have rear coilovers and I like to have matching set ups all round, and I got a mint gmax set up really cheap
So have have gmax front shocks with -60mm springs and coil overs for the rear for sale
And I've put on a full -40mm kit with polybushes, new steering knuckle, strut brace, rose jointed lower arms, cosworth 4x4 brakes, 5mm spacers and hopefully will have a 10mm axle widening kit soon
The car is imperial blue with team dynamic pro race 1.2s in white 16"
So it's getting there now
Rsmark86
Postby mikeymikeyp on Sat Sep 21, 2013 2:54 pm
MY opinion is that my nike air max handle better than g max
mikeymikeyp
Postby Rsmark86 on Sat Sep 21, 2013 4:18 pm
I will upgrade later but I've fitted all 3.5 front end now, and just didn't like Having odd shocks on it
I prefer gaz coilovers but can't afford them at the min
Rsmark86
