MK3.5 SI Brake Options
19 posts • Page 1 of 1
Am looking to upgrade the brakes on my si.
I have bought new pads just need new disks.
What are my best/cheapest option to upgrade the standard brakes already on my si.
- kelvin156
Re: MK3.5 SI Brake Options
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
well i picked up my st150 278mm brakes for £120 with vgc pads and discs..Fit straight on without any modification youll need 15" wheels tho
- Luke1990
- lowsi
What will i need to buy Disks, Calipers, Pads anything else.
Did buy new Ferrodo Performance pads for my current set up, Will i need new pads with me getting bigger disks etc ?
- kelvin156
Also depends what wheels you have.
- Tweek
- Your car: VW Golf GTD
Have 15" wheels.
Am not looking to increase power just upgrade brakes.
Am i best going for bigger disks of just getting same size but grooved/drilled ?
- kelvin156
If you don't want mor ethan the stock power swapping to a decent pad like theg Ferodo DS2500 and getting some braided lines and flush the system through with fresh DOT-4 will suffice.
My understanding is that getting drilled or grooved discs will just make the discs cool down quicker, so id expect you to only notice the difference under considerable, sustained heavy braking. Or you could just get some fancy pads for the standard brakes which should make you stop a bit quicker. Whereas if you get biggers discs, i.e. the ST150 ones, (278mm) this dramatically increases the actual stopping power of the brakes.
If you go for the 150 setup then you will need the Carriers, Calipers, discs and pads all from a fiesta ST150.
really depends how much of an upgrade you are after.
- Luke1990
get some Ferodo premier Disks...
uprated pads (I have some Greenstuffs for sale)...
flush and fill with Super DOT4 fluid (Ford can order this for you if they don't have it as a stock item)
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
- Maff Si
- Your car: Nothing til end of the month
i have new ferodo premier pads already, do you have disks for sale ?
- kelvin156
I have these for sale...
EBC Green Stuff Front Pads
Brand new boxed £30 ono
Part No: DP2415
fits...
Fiesta 1.1/1.3/1.4 (ABS) (93>97)
Fiesta 1.6 XR2 (82>89)
Fiesta 1.6 RS Turbo (90>91)
Fiesta 1.8 D Inc Van (ABS) (93>97)
Fiesta RS 1800 (92>95)
Fiesta 1.6 Si (93>95)
Fiesta XR2i 8v & 16v (90>93)
Escort/Orion 1.6 RS Turbo (85>86)
Escort/Orion 1.6 XR3i (86>90)
Escort Mk4 (86>91)
Sierra/Sapphire/P100 Pick-Up (87>93)
Part No: DP2415
fits...
Escort Mk4 (86>91)
- Maff Si
I doubt anybody will read this but.....if i upgrade the front brakes, will the standard fronts fit on the rear? sorry if thats a retarded question...
- Luke1990
Luke1990 :I doubt anybody will read this but.....if i upgrade the front brakes, will the standard fronts fit on the rear? sorry if thats a retarded question...
not a direct fit cos std rears are drum brakes!
- Maff Si
I knew they were drums i was just checking they haven't got the same mounting, cant say ive ever taken any off tbh. So youd need to go for the mk5 rear beam to get discs on then?
- Luke1990
Why do you want rear discs?
For looks mainly i know the drums are ample stopping power i was asking if you could replace the rear drums with the front discs as when i get my 278s on the front ill have a set of standard fronts hanging around. that was all
- Luke1990
How would you make the handbrake work?
- Ollybee
Be useful if somebody just answered his question
No I doubt they would fit, most people who do the conversion to disks on the rear use rs2000 disks I beleive.
Although as most people here will end up saying, rear disks are deadly.. although I have no experience on this....
- happypaul
