Mk3 cylinder head problem
Postby Coolbluelights on Fri Jul 26, 2013 7:59 pm
Hiya everyone, I'm new to the forum.
I bought my fiesta from a scrap yard as a project.
I have been trying to start it and had no luck, turns out a piece of metal had got lodged between the belt and the crankshaft causing the belt to snap.
I now recon the valves are damaged and wanted to know if it would be cheaper to replace the cylinder head completely (got quoted 100 quid for a replacement) or to replace the valves
Bradley
Coolbluelights
Your car: Ford fiesta mk3 1989 1.4 cvh
Re: Mk3 cylinder head problem
Postby FRSJON on Fri Jul 26, 2013 9:10 pm
hello and welcome :) what engines in the car?
FRSJON
Postby Coolbluelights on Fri Jul 26, 2013 11:17 pm
FRSJON :hello and welcome :) what engines in the car?
It's a 1.4 petrol cvh
Coolbluelights
Postby AW0L on Mon Jul 29, 2013 10:57 am
best bet is to remove the head and see if the valves are damaged, worst case is if the valves are damaged, chances are the pistons are too...
being only 16, this will give you great hands on knowledge on how to repair your car... i started at 16 on vauxhalls, i am now 30 and built 5 engines and repaired more than i can remember
AW0L
