mk3 fezzie supercharged : Technical Problems / Queries | Fiesta Forums
Postby jimjams72 on Sat Jun 07, 2014 9:56 pm
Im thinking of doing a 2.0 silvertop conversion with a merk supercharger any tips ideas help or guides
jimjams72
Your car: fiesta xr2i
Re: mk3 fezzie supercharged
Postby FRSJON on Sat Jun 07, 2014 11:53 pm
dont spend much on the engine but spend loads on engine management would be my advise...
FRSJON
Postby boeb on Sun Jun 08, 2014 2:04 pm
Pretty sure when boy in local club(Jpa) done it he got it running good on ofab ..mini charger am sure..
boeb
Postby MikeyMk5RS on Sun Jun 08, 2014 7:44 pm
Depends what Mercedes charger your planning using. We did a supercharger conversion on a lexus is200 a couple of weeks back using a merc kompressor charger
MikeyMk5RS
Postby jimjams72 on Fri Jun 13, 2014 10:22 pm
MikeyMk5RS :Depends what Mercedes charger your planning using. We did a supercharger conversion on a lexus is200 a couple of weeks back using a merc kompressor charger
How did you rug it up and what pully did you connect to also can you recommend a management system
jimjams72
Postby MikeyMk5RS on Fri Jun 13, 2014 11:00 pm
jimjams72 :
The supercharger we used allowed a remote fit, ie it didn't need to be on the inlet side. the tensioner for the supercharger belt ran from supercharger pulley. Depending how much psi of charge your going to run, the standard one we used was only 3psi, that meant it could run on a piggy back ecu without the need to monitor boost. I would recommend Syvecs engine management systems, we can supply you with a kit if required.
MikeyMk5RS
Postby georgiocat on Sat Jun 14, 2014 9:59 am
Excuse me, but spending money on something that will run that kind of boost is kind of false economy... I may be wrong but the gain will be little for what you are going to spend. Unless you just want to experiment with a supercharger and don't want to have higher gains... With just a T3 wou can keep down boost at 7 psi and have higher gain with OFAB or OFAC... In my opinion, it doesn;t worth the hassle and the money for so low boost... I may be wrong, but...
My Ford Escort ride
georgiocat
