Mk3 heater fan resistor pack location
Postby ctk900 on Fri Apr 14, 2017 3:47 pm
Hi,
The heater fan on my new mk3 only works on the faster speeds. Normally I believe this is caused by a failing resistor pack. On other fords I've owned the resistor pack is in a little hatch under the glovebox, but I cannot find it anywhere on the mk3 to replace it.
Does anyone know where it can be found?
Thanks.
ctk900
Your car: A fiesta...
Re: Mk3 heater fan resistor pack location
Postby knuckles on Wed May 03, 2017 1:57 pm
Engine bay , under the plastic cowling that hides the Heater motor lives the resistor
Check the switch also - but my money is on the resistor or the wiring to it
knuckles
Your car: Fiesta Rs turbo
