Mk3 / Mk3.5 Strut conversion
Postby Dazza on Thu Jan 15, 2015 7:20 pm
All,
Obviously the Mk3.5 struts are thicker than Mk3's. I have an Si and I want to fit some coilovers I've got from a Mk3, I was thinking of making up a shim to bridge the gap between Mk3.5 hub and Mk3 strut, I think its about 1.5mm - Has anyone done this before and if so, do you have a picture of the shim?
Dazza
Re: Mk3 / Mk3.5 Strut conversion
Postby reithy on Sun Jan 18, 2015 8:03 pm
Did it years ago, used a strip of copper as a shim, then put the strut in and did the bolt up tight.
Will see if I can get a pic when at my parents.
reithy
Postby Dazza on Sun Jan 18, 2015 9:33 pm
Cheers Reithy
Dazza
