mk4 into mk3 interior light fitting guide (pics) fao m4x xx
Postby AGAR on Sat Feb 18, 2006 10:12 pm
Tilston :yeah they do!!! not sure about the alarm sensor though i havent wired it up yet!
Nice one :D
How'd you wire in the connectors for the two other buttons so the two outer map lights come on?
AGAR
Postby Tilston on Sat Feb 18, 2006 10:22 pm
i just wired up the 3 plugs from the old one! :)
Beep
Tilston
Postby Tilston on Sun Feb 19, 2006 12:30 am
heres some more. i couldnt get a good pic of the middle light one cause its in the dark and was way to bright!
like maxes, the light does creap out a little bit! :rolleyes:
Beep
Tilston
Postby AGAR on Sun Feb 19, 2006 1:15 am
Yeah my mk4 light doesn't fit in exactly either - so i used superglue round the edges.
AGAR
Postby Tilston on Sun Feb 19, 2006 3:17 am
i didnt super glue. under the clear lense in the middle i put a screw in each corner (cant see them with cover back on). might see if i can get a flusher fit tomorrow.
for wiring up the two other light, when you look you have 3 wires and 2 plugs. you need to hack the one plug into 2. the door sensor and the ground wires go together and the power lead onto the other one located on the metal plate.
Beep
Tilston
Postby Tweek on Thu Mar 02, 2006 8:39 pm
Meh i'm a bit stuck with mine. I cut the prongs off so I wouldnt have to drill anything but I can't seem to fit the metal plate on the back without having the need cut a huge hole out for it :-?
I noticed the angle prevents it from sitting flush too. So close, just trying to get it to sit properly :cry:
Your car: VW Golf GTD
Postby Tilston on Fri Mar 03, 2006 5:07 pm
Tweek2k5 :Meh i'm a bit stuck with mine. I cut the prongs off so I wouldnt have to drill anything but I can't seem to fit the metal plate on the back without having the need cut a huge hole out for it :-?
cut a huge hole then :lol:
Beep
Tilston
Postby Hotstrat2k on Thu Jan 11, 2007 1:36 pm
fitted mine in 15 mins the other day just chopped everything off the back and cut out ta big enough hole in the lining
wired it up
its didnt sit flush so i also twatted it with a hammer till it was bent in enough and then when it sat flushsh just glued it round the edge no light escapes annd it is stuck firm
:D :D
Harry
Hotstrat2k
Postby Tweek on Fri Jan 26, 2007 10:20 pm
Cut everything off the back you say? hmmmmmmmmmm shall have a look at that.
Postby Hotstrat2k on Sun Jan 28, 2007 4:05 pm
exept the metal bit behind the light :D
Hotstrat2k
Previous
