mk4 into mk3 interior light fitting guide (pics) fao m4x xx
45 posts • Page 2 of 2 • 1, 2
i didnt super glue. under the clear lense in the middle i put a screw in each corner (cant see them with cover back on). might see if i can get a flusher fit tomorrow.
for wiring up the two other light, when you look you have 3 wires and 2 plugs. you need to hack the one plug into 2. the door sensor and the ground wires go together and the power lead onto the other one located on the metal plate.
Beep
- Tilston
Meh i'm a bit stuck with mine. I cut the prongs off so I wouldnt have to drill anything but I can't seem to fit the metal plate on the back without having the need cut a huge hole out for it
I noticed the angle prevents it from sitting flush too. So close, just trying to get it to sit properly
- Tweek
- Your car: VW Golf GTD
Tweek2k5 :Meh i'm a bit stuck with mine. I cut the prongs off so I wouldnt have to drill anything but I can't seem to fit the metal plate on the back without having the need cut a huge hole out for it
cut a huge hole then
Beep
- Tilston
fitted mine in 15 mins the other day just chopped everything off the back and cut out ta big enough hole in the lining
wired it up
its didnt sit flush so i also twatted it with a hammer till it was bent in enough and then when it sat flushsh just glued it round the edge no light escapes annd it is stuck firm
Harry
wired it up
Harry
- Hotstrat2k
- Tweek
