Mk4 Silvertop Zetec 16v -- aim is 140bhp, 2.0 cams in! : Member's Gallery - Page 33 | Fiesta Forums
Re: My fiesta, mk4 Zetec 16v -- the aim is 140bhp
Postby jonyb4 on Tue May 25, 2010 11:42 am
:lol: yea but the misses and work also dot hat, just theyre better at it lol
Postby mrorange2 on Tue May 25, 2010 12:06 pm
I dont like snickers lol Mines more than sluggish i think the poor girl is past her best.
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby jonyb4 on Wed May 26, 2010 1:47 am
Seen a chevvy impala at the scrappy today, was nice since im a big supernatural fan :D
well it was inlet day today
comparisons of the So and Ho
gasket one is SO
So
Ho
SO left, HO and then 1.6
removing the Throttle body off the 1.6 wasnt easy, last owner used loctight and garden screws to hold it on
so cut off the bolts and removed all the sensors
ports were a bit merky
and polished them up
polished up the ISCV also
had to make a make shift gasket for it as the rubber one collapsed after i removed it from the 1.6 :( i need a new one
had some trouble getting it to idle right after it was back together, after some potching and some luck, it was ok, didnt drive it far as it was something past 11, but it felt more powerful and torque was higher :devil: :devil:
after a 2.0 ECU next, the mrs is looking for some cams for me at the same time, wink wink wayne :D
Postby moondustka on Sat May 29, 2010 12:15 am
cool - sounds like it's on it's way up then :D
moondustka
Postby jonyb4 on Sat May 29, 2010 12:22 am
:Q
currently running it witht he maf unplugged, bloody blighter isnt worth the trouble its causing so F it lol
Postby jonyb4 on Wed Jun 02, 2010 12:52 am
desprate to get rtid of my heat soak problem, i tried to revert to the standard air box, but since this engine was never meant to sit in the mk4
its harder to get it to standard
drilled for better flow
VERY streched to fit as maf wouldnt fit in the box hole, a puma 1.7 box would have worked
it sounded good, and went ok, (at the time my maf was franked but i didnt know it was making it sluggish) so i blamed the airbox, with a better panel filter it would have worked :Q
but i went back to induction kit, and decided to wrap the underside of the intake pipes in silver stickyback foil
i gotta admit i didnt expexct much, but f**k me it works a treat, the pipes bearly get hot, compared tot he rocker cover theyre lukewarm, event he silicon hoses get hotter and they are usually cool compared, so heatsoak has been defeated to a degree,could still do with a better cold air feed :Q
also i fitted my spare maf, ive never known what its for maybe a 2.0 the way it can hunt on idle, bt atleast its given my power back without having to unplug the maf and lose 10mpg :?
so im glad its running sweet again :D
Postby Ratspeed on Wed Jun 02, 2010 8:53 pm
good news buddy
Ratspeed
Postby Dave G fsi on Wed Jun 02, 2010 10:31 pm
All sounds good mate! :aviator:
Hope I get to see/hear her at the rr day! :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby jonyb4 on Thu Jun 03, 2010 1:27 am
cheers chaps
sorry dave bout its unlikely ill be coming tot hat, its a bit unviable for me to travel that far considering theres a RR within 20miles of me, and i wont have the car set up how i want it by then :(
hope you have a good day though mate :Q
Postby dontpannic on Thu Jun 03, 2010 2:22 pm
Nice to see you've put the standard air box back in. A far cry from when you told me whats the point of putting the air box back in:
jonyb4 :sounds like alot of work for a bit of noise, a £12 ebay cone filter would do perfectly, and will look better
:lol: :lol: :lol:
How times change eh? LOL. Noticed a difference in MPG?
Postby Excursion on Thu Jun 03, 2010 3:37 pm
I will have some 2.0 cams if you're interested?
Postby Dave G fsi on Thu Jun 03, 2010 10:56 pm
jonyb4 :cheers chaps
:cry:
Fair enough though mate, it is abit out of your way! :lol:
Maybe next time :)
Dave G fsi
Postby jonyb4 on Fri Jun 04, 2010 1:24 am
Dave G fsi :
:cry:
Maybe next time :)
yea bit too far considering, sorry mate
dontpannic :Nice to see you've put the standard air box back in. A far cry from when you told me whats the point of putting the air box back in:
:lol: :lol: :lol:
sorry mate but read up again, the box is back out, was rattling around, i thought it was slowing it down, so i took it back out, so back to standard cone its always had lol
Excursion :I will have some 2.0 cams if you're interested?
ou have a Pm mate :aviator:
Postby jonyb4 on Fri Jun 04, 2010 11:47 pm
Today i decided to strip the rear beam off the car and repaint, and correctly convert it to have an Anti roll bar
to be an extended job the capri was once again kicked out of the garage :P
nicely fresh painted garage floor too :)
so back end all stripped, wheels, hubs, suspension struts and beam off, noticed that one of my wheel studs was chewed up, so lucky i had a spare off the fronts from when i fitted the longer ones the other day
so that was replaced, cant joke around with wheel nuts...
excuse my hanging the hubs on the brake lines :aaah:
started to drill the holes needed for the inside mountings, the minion at work :Q good job matt :)
one side finished, the cutout shouldnt alter the beam structually to much, need to use some washers too :rolleyes:
then it was time to strip it back down and paint it
and the Arb
hoping to take the arch linings off tomorrow and red hammerite under them, silver is so not a good idea, rust shows through and gets really dirty quick! hammerite red is a good colour match to radiant red anywhoo
get it built back up and see what this arb can do :devil:
im certain standard mk4 beamsare stronger than mk3 ones, seems to have more and bigger re-enforcement on it 8)
Postby jonyb4 on Fri Jun 04, 2010 11:49 pm
just noticed how bad that first pic looks lol :oooh:
need a new fuel tank, need to paint up my spare and treat/paint the carrier :aaah:
Postby Minstral on Sat Jun 05, 2010 7:43 am
think its safe to say you need a new spare wheel carrier. never seen rust that bad on one
Minstral
Your car: *
Postby jonyb4 on Sat Jun 05, 2010 7:25 pm
lol its not one of them ones, its a skimpy type one, more frame than sheet
Postby mada01 on Sun Jun 06, 2010 3:05 pm
just get rid of it and save some weight haha :lol:
i know how much a pain taking the ream beam off is and refitting it!
mada01
Postby - Danny Boy - on Sun Jun 06, 2010 11:46 pm
Ohhhhhhhhhh JONY.... haha. Looking sweet mate, keep up the good work :D
- Danny Boy -
Your car: Fiesta Si 2.0
Postby Pumatt on Mon Jun 07, 2010 5:33 pm
LOL....I am a bit like your minion these days! :lol:
And that spare wheel holder is off my old fiesta which was a 99 and had no rust elsewhere :P odd.
Ford Escort GTi
Ford Puma 1.7 ..... in bits for scrap.
Pumatt
Postby moondustka on Mon Jun 07, 2010 11:12 pm
Good work :D
moondustka
Postby jonyb4 on Tue Jun 08, 2010 12:29 am
continuing
buying waynes cams tomorrow so 130bhp soon :Q
if anyone has a pre pats 2.0 ECU for sale please let me know, im after one :)
Postby xr2irhys on Tue Jun 08, 2010 7:33 am
looking good , as for your neons why not wire them to the remote on the amp , which means will come on with the stereo rather than on a switch :)
your rear chaissis rails dont look to good :(
xr2irhys
Car: 1996 Ford Fiesta Classic
Postby jonyb4 on Tue Jun 08, 2010 10:50 am
aye suface rust plotted all over underneath :rolleyes: :(
as for the boot lights, i dont want them on all the time, the switch is only for when leaving the boot open too long, they light up when the boots opened via the switch on the pin connector plate, you just open the boot and they come on :Q
Postby mrorange2 on Tue Jun 08, 2010 11:45 am
Looking good mate not a fair of neons but each to there own.
Keep up good work. Look forward to hearing what you think to the 130bhp setup!
mrorange2
Postby jonyb4 on Tue Jun 08, 2010 1:27 pm
cheers mate, if you swap me your RS ecu ill let you know how the 130 is :lol: :bonkers:
Postby mrorange2 on Tue Jun 08, 2010 1:51 pm
Dont think my RS ECU will work with it mines a PATS one. Ask Ratty he might have a early RS1800 ecu from his.
mrorange2
Postby Smo on Tue Jun 08, 2010 2:03 pm
PATS is a separate system on all MK3s that were fitted with it - it's completely stand alone from the ECU :)
Smo
Postby knuckles on Tue Jun 08, 2010 9:29 pm
Minstral :think its safe to say you need a new spare wheel carrier.
LOL :lol:
knuckles
Your car: Fiesta Rs turbo
Postby fiend on Tue Jun 08, 2010 9:42 pm
:aaah: :aaah:
Might want to use some rope or a bungee cord to hold the drum up, look how stretched the brake hose is!
fiend
Postby jonyb4 on Tue Jun 08, 2010 11:25 pm
unfortuanatly matts ecu is a OFAB/C one so it wont have an edis, wont run my late zetec engine :(
you sure no mk3's had pats internally simon? speaking for all mk3's including 3.5's or just mk3s
yea wasnt clever of me to leave the hubs hanging like that :rolleyes: should have put a paint tin under them lol
and the carrier honestly hasnt ratted much, its meant to be skimpy like that :lol:
Postby moondustka on Tue Jun 08, 2010 11:37 pm
jonyb4 :and the carrier honestly hasnt ratted much, its meant to be skimpy like that :lol:
Just ditch the whole thing - i did :lol: less weight :P
moondustka
Postby jonyb4 on Wed Jun 09, 2010 12:14 am
lol i am for now, i liek to be able to see my rear beam :Q :D
cant wait for these cams :D :D
Postby mrorange2 on Wed Jun 09, 2010 9:31 am
Jony, Matts RS1800 ran on a 2FDC ECU not OFAB\C the chip i got off him was programmed for the 2FDC.
mrorange2
Postby jonyb4 on Wed Jun 09, 2010 8:32 pm
what you mean mate? :-?
