Mk4 Silvertop Zetec 16v -- aim is 140bhp, 2.0 cams in!
Re: My fiesta, red mk4 s2 16v Gearbox spacer question?!
I think that's a mint idea mate hope it works
looks $hit goes good
- FezzyGTI
- Your car: Mk5 zetecs 2.0 ITB's
It should be the corect thickness otherwise there will be undue wear on the fingers and release bearing.
It's around 1mm IRRC.
aye Excursion but the clutch and bearing setup its got atm is a mix, and theyre different so it aint working, ill have to do some measuring
these arrived today, cheers to cookie456_the2nd , bought the polies from Flo flex, really cheap fair do's to them, front escort arb bushes, seem identical to the mk4 fez (i still have the escort crossmemeber out the back), and Si rear arb bushes for the new beam, K&N induction kit, and now i got a spare cone and 1.6 si Maf lol (got 2 of them now)
one of the clamps is snapped
just be carefuly when u prise open the other brackets. paint it as well
- Minstral
- Your car: *
to be continued on msn...
Just read through the last few pages of your thread mate and its pretty cool. I'm not one for electics unless its on front of me so I must admit alot of that didn't make much sense to me however I must say you'v done a sterling job so far.
Just thaught i'd check your thread out anyways since u'v bin talking to me a little through pm. I didn't realise you live in wales. I live in St Athan near Lantwit major n barry. We should meet up sometime n take some piccy ect n u can show me some of the better driving roads in the vallys as I'v only bin here 6 months n not got out much yet lol.
Ollie
Ollie
- niracka
- Your car: E46 M3
ha cheers mate, yea the vallies near me have some cracking roads, i almost killed myself on one of them lol
yea if you wanna meet up one day great you can show me how the blacktops get it done
i live right at the foot of the afan vally, so a great drive is never far away
Ah yea been meaning to go to afan mountain biking.
Are you going to fitp this year??? If so might be an idea to go down together prior to meeting convoy??
- niracka
- Your car: E46 M3
i plan to got here yea , best get the savings going lol, yea be nice to drive with soemone from wales, ive always crossed the bridge on my own to meeds and shows
no buggers from wales lol
add me on msn if you want mate jonyb4@hotmail.co.uk
Theres a guy from fiesta guides living in bridgend too mate should get him out too.
Ollie
Ollie
- niracka
- Your car: E46 M3
lol theres two! ive met both fo them, good lads
ah nice one we [ERRR] def hav a lil meet up then
- niracka
- Your car: E46 M3
coming along mate good work.
- THEHOG~
cheers man
Is she working yet man???
- niracka
- Your car: E46 M3
not yet,
sort of an update, bought 4 ghearbox spacer plates today off a mk4/ka 1.3 HCS and 3 off a mk3/escort HCS too
althoguht he mk3 ones have the starter onthe front, i shall cut them off, aslong as two of the palces are doing a good job of a seal, i dont mind abotu the others, each are 2mm thick, so i will have to find out how many i need simply by trial and error really, all i can do atm
failing this, i will have to buy a mk4 Diesel clutch kit, but atmt his is the cheapest option so will do this first
will update when the box is off and ive fittd the plates,
also anyone know where i can buy new rear ARB brackets for a mk3?
rs rob has bought some for his car
diary-of-jph-2-1-zt-feb-22nd-rs-steering-wheel-updated-vt134259/page420/
reading it he said that some 1 type is still available, but the other isnt. loking at the pictures it looks like the si arb bracket sre the ones no longer available.
ask him he'll know
ask him he'll know
- Minstral
- Your car: *
i did once no one replied lol, ill pm him this time
thanks
thanks
Re: My fiesta, red mk4 s2 16v Box dropped, clutch knackered
Well back up in the air with her...
on its arse with fluid still in, makes things easier as fulling it up was a right ball ache
as it was being dropped, i noticed some strands of string and what looked like fibers or hair, i thought "god its the clutch..."
i wasnt to be wrong either...
flywheel side
so yep clutch is shagged, will be needing another
not 100% on which i should get, a mk4 1.8 diesel is the same disc diametre, 210mm,
or maybe a 1.6 Zs one or 1.7 puma one?
anyone able to suggest one?
flywheel side
The question is, was the failure because of a faulty clutch plate, or because there is a problem with the thrust bearing?
- Rhinopower
- Your car: Volvo FH330
niether to be fair, its simply because the clutch wasnt build to support the gearbox/slave cylinder , its just too big in width and was in contact with the housing that i pointed out
im preying that the diesel clutch fairs better, yet again im thinking its down tot he size of the flywheel and thw width of it all, so spacing it is needed
i whish i can get in touch with someone whos fitted a mk4/5 puma box to one of these engines
ask somone whos put a cvh / rs trubo in a ka as they share the same gearbox
someone might be able to help u out
- jonboisescort
Car: 1994 Ford Fiesta
right i've got a few points here to make,
-why have you gone for a si arb from an older car? it would make alot more sense for you to put a zetec s rear beam on
as their known for their stiffness and good handling, so would save you dealing with old brackets etc
- a mk5 z-s clutch is 200mm and a puma is 210mm
as your going from a 1.3 ( or even 1.25 - 1.4zetecs) you'll need to change to the z-s flywheel and then the puma clutch can go straight on
the standard puma clutch was even fitted to the FRP which was 155bhp, so will be fine for you
been researching on zsoc as i've just upgraded the g/f's mk5 z-s clutch lol
the clutch slave/thrust bearing is the same on most fords puma,ka,focus,fiesta etc
but very worth while changing while your here
one more thing stay away from q&h clutches
either a new ford part, LUK etc
- RS rob
Could you not have just put the ib5 box on???
- niracka
- Your car: E46 M3
cheers john ill talk to moondustka or someone similar
Si arb cause its far cheaper, and due to the fact my mk4 is an early model (pre 98, when the revisions were done) so id also have to chamge my rear shocks for late mk4 or mk5 ones, costing even more
clutch ill think about, but so far im edging more for a fiesta diesel one, but i will look into the flywheels, the zetec one does seem alot larger/thicker
my slave cylinder and bearing was done 10,000 miles/ a year ago when the clutch was done
and ollie it is an iB5 box, just mk4/5 use the hydrualic version
RS rob :right i've got a few points here to make,
i was going up the mountain for a little spin, lol sounds odd but i love to do it, trait of living in the vallies
and i noticed one of the afan forest ranger gates was open, so i thought it slip in and take a look, i love forestry
so i took some pics, may have been a bit over board
some sort of wall
my favorite
but then a ranger found me lol said he was gonna lock the gate, so had to leave
im worried that im starting to get attached to this car lol, meant to be selling it
some sort of wall
my favorite
LOL at the clutch. Im sorry
Honestly, thats s**t, was it new or 2nd hand clutch? Ive not been on for a while and cba to read it all again to jog my memory lol
- - Danny Boy -
- Your car: Fiesta Si 2.0
its not meant to be like that, not as if i was revving it while it was slipping or something, the gearbox was crushing it in the pressure plate, and it was spinning and ended up like that
jonyb4 : i love forestry
I know what you mean, gotta love bush
- Ratspeed
LOL
lol damn it i cant think of any come backs
jonyb4 :its not meant to be like that, not as if i was revving it while it was slipping or something, the gearbox was crushing it in the pressure plate, and it was spinning and ended up like that
Ohhhhhhhhhhhh i seeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. Best get a new clutch and some spacers put in then then sharpish
- - Danny Boy -
ha tis my exsact plan!
Re: My fiesta, red mk4 s2 16v New clutch ordered!
after a local forum member left after i fitted half of his lowering spring kit (coming back for front tomorrow)
i decided to power wash the cars, bloody three of them i done
the mk3 was stinking with mud all over it from when i decided to do a tad of off roading
my mother was complaining one of her fiestas doors was making an embarrising noise, its got a dented front end but this she moans about lolm, some simple high temp grease sorted that on the position lock thing in between the shuts
then washed that
done the engine bay of the mk3
and then washed my mums other car her Chrysler sebring
Rear wheel arch:
and after
gotta love the Mobility scheme, brand new car of your choice every 3years, insurance, tax and any maintenance or repairs free of charge, for a monthly free, and some models have an upfront fee, but its alot cheaper then actually buying the cars, all on a Disabled badge, almost makes it worth being disabled
HUUGE 18" wheels covers all round discs
full leather interior, all the gizmos you can think of except built in satnav, awsome Boston audio system, had a blast listening to Queen full blast
125bhp 2.0l turbo diesel VW engine, six speed box, shes quite nippy
we have 6 cars at our household
Dads mk1 Capri, bro's Clio, mums chrysler, mums mk4 Fiesta, my mk4 fiesta and my mk3 fiesta
you can imagine how our neighbours feel about us
then washed that
Rear wheel arch:
and after
Bed your liked on your street lol. I hope this new clutch sorts you out mate. U'l have to show me what nice roads are up there to be driven and we can get some pics n vids
Ollie
Ollie
- niracka
- Your car: E46 M3
