mk5 panther black 2.0 zetec *Now going ZT*
Re: mk5 panther black 2.0 zetec *Now going ZT*
yea i can guess why you would, but fair playt he guy must be making a killing once its programmed into his CNC
yup the joys of having a cnc machines a!
- leighk2010
I have a set of new Focus RS Pistons, rings and rods £450.
Excursion :I have a set of new Focus RS Pistons, rings and rods £450.
i wish could afford them mark! but also i think my bore will be way to loose to uses them in any way
- leighk2010
just had a start date for my job so let the good times roll!
- leighk2010
leighk2010 :just had a start date for my job so let the good times roll!
irted at mine this monday just gone, first week of work over, phew lol
Right guys and girls update on the spec i am now going for.
The spec.
2.0 blacktop
Diamond Racing forged pistons (deposit down on them)
Stock rod's with apr bolts
Rebuilt head with new valves and seals (deposit down on this)
Exhaust side ported
Adaptor plate & Escort rs turbo t3 manifold
Front breather blocked and new one drilled into back of block.
T3 turbo
Sump modified for oil return
Mega squirt v2 ecu (unless a better ecu is sourced)
Aiming for around 220-250 bhp
Few pics of my mock engine in its new home in my living room and also can see the front oil blocker i brought.
The spec.
2.0 blacktop
Exhaust side ported
T3 turbo
- leighk2010
spec list sounds good
what compression ratio you aiming for?
all sounds bang on to make them sort of power levels
i belive with them pistons it should be around the same as running Je pistons etc which is around 8.5-1 but as i'm not after mega power should be good
- leighk2010
also forgot will be running a front mount ic as well
- leighk2010
yup again that sounds about right
what you doing for an inlet??
using focus inlet manifold going to try and source a focus rs tb as there metal
- leighk2010
leighk2010 :using focus inlet manifold going to try and source a focus rs tb as there metal
I have a focus RS inlet for sale £150 - it's the real deal with the elbow and the metal reinforcement bracket for the injector area.
I also have a brand new set of FRS injectors £100
Excursion :leighk2010 :using focus inlet manifold going to try and source a focus rs tb as there metal
i will be in touch mark! i think i should just chop my arm off and give it to you as you have all the bits i need do you want my right or left!
- leighk2010
useful one
depends which you tug with dont it, dont give away your
no need to tug that's what the g/f is for..
- leighk2010
leighk2010 :no need to tug that's what the g/f is for..
shhhh lol
- leighk2010
glad your doing the turbo built proper mate, with a rebuilt bottom end the milage wont really count for much, i love the TD 1.2's
one of my favourite wheels
cheers mate yup with the rods and pistons means i can push the engine to a nice round 300 + bhp and not have to worry to much
things i still want to order in next few months are
eagle rods
fibre-glass boot
polycarbonate windows
buck seats and harness
just to name a few
eagle rods
fibre-glass boot
just to name a few
- leighk2010
well been a a few weeks have made some progress on the car.
thanks to a mate over on zsoc got a smooth boot which need a touch of work and re-spray but he let me have it for a good price so have that fitted just need get some struts to keep it open. went for this over the fibreglass boot just because of the price i got it
fitted my Mondeo mk3 calipers and mite get away with not even grinding them down its very close but with the td 1.2s they spin free etc
also just a pic which i saw when working on the car and thought got to take how good would this stance be..
Really need to get some new coilovers after selling the aps or at least some shocks to get the car a rolling shell again.
Tomoz i plan on painting the inside and engine bay white. this will just be a hammer rite job with a roller as dont want to fork out the £££ to have it sprayed inside.
Also plan on fitting the manual rack i now have.
today have stripped the engine down to the block which i will be painting and honing out ready for the rebuild to begin.
have started to paint the inside white using hammer rite not the best but trying to spend the money on the engine and not the car its self. the new hammer rite can be used with a roller so this is what i have been using long way to go yet though.
engine been taken apart
weird crystal stuff by the water pump.
good news on the crank looks like it will just need a polish on some of the jernals and can use standerd size bearing again which will be nice not bad for a 160k crank
and all packed away for today as had to go pick the g/f up.
- leighk2010
Looking good
That ride height wouldn't be very practical on track,
lol jony that's just a jack holding up the rear beam as there is no suspension on the hole car the wheel aint even touching the floor
- leighk2010
lol heey, gimme a break my phone screen is small compared to a monitor!
1.2's suit a zetec s down to the ground! literally
well engine bay now nearly stripped so i can source a mtx75 box and start mocking up all the mounts and get them welded in and paint the bay.
Why taking the bottom stabiliser mount out i have noticed its quite similar to the focus so hopefully will not need much to fit that. Then need to sort some drive-shafts out, but getting there slowly.
Once bay is painted i will be able to fit my manual steering rack and decided 100% if to fit the brake bar and non abs master cylinder i have back in or scrap the lot and get a pedal box.
- leighk2010
touch more of a update:
i did not want to ruin my stickerbomb rocker cover so will be keeping that for shows etc so i had this silvertop cover spare so give it a little bit of paint what do you think?
also i am know 100% going mtx75 gear box out of a 2.0 focus so got hold of a bottom stabiliser mount it should bolt straight up to were the fiesta stabiliser mount goes but mite be a touch on the short side but untill i go to the car and see i wont no for sure.
- leighk2010
i think baking it on your hob isnt the way about it
looks good, crackle paint make me cringe when i feel it
- leighk2010
- leighk2010
ooh nice, how do you mean 3 outlet
how much that set ya back? id love a bigger intercooler for the bumper in my escort TD
Not the sharpest knife are we Jony, 3' as opposed to 3''.
Ex Fiesta RS Turbo owner
- filtra
it was late!
honestly didnt see that apostrophe
lol jony yes 3 inch out lets on it
it was around £90 delivered of ebay have to look around as they very from size to size etc
not the best pic only had my phone on me but have had to chop quite a bit out of the front cross member still need to cut more out the bumper as well to fit over will probs get this done tomoz to show it you with the bumper on as well but here a pic of the cooler fitted using cable ties for now why i sort out bumper etc
- leighk2010
that looks good, its quite big too
so what do you drive daily then mate?
me and the g/f sh are her saxo vtr i use to have a vts
- leighk2010
