mk5 panther black 2.0 zetec *Now going ZT*
Re: mk5 panther black 2.0 zetec
ah good luck mate
im in a similar boat, owe money to a few ppl and no job to pay for it
recently had a interview as a fitter for halfords, but the hours are low atm even if i do get it, will only be £15 better off than the dole after ive payed for petrol every week, but overtime is avilable
well got the job Woop 10 ph here i come just got to wait for a start date to be arranged now. so when i start got a few little bills to be sorted then full steam ahead on this project
- leighk2010
woo, f**k thats good rates
whats that doing then?
building engine on a production line
its a great rate and plenty of over time as well
- leighk2010
Just won some 300mm mondeo mk3 brakes
- leighk2010
nice, hope the discs werent part of the price
nah mate got the calipers for £32.50 posted so cant complain will be gettiing st170 disk and then looking into some mintex 1144 pads or ds2500's
and now with the new job on the cards mite go turbo
- leighk2010
oo thats nice and cheap
ot sure abotuthe turbo, might want a lower milage engine first
fit this test it, and while driving it built a zetec turbo
if going turbo engine will be rebuilt fully not to sure if will go
forged pistons and rods,
st170 pistons and rods (as the forged rods)(pistons are high cast)
or the vaxhuall pistons machined to fit,
as dont want to use a de-comp plate. will be running erst manifold either drilled and tapped to head, or using adaptor plate, a t3 turbo of some sort as aiming for 250 bhp
will also use my focus inlet but try and source a metal focus rs itb
dont see point of getting it running N/A to then strip it all back down to build up again,
will either then run it on focus rs management
or omex or megasquirt etc
- leighk2010
if you dont want to use a decomp plate, you cant use St170 pistons, the compression ratio on them is too high (10.2:1)
your gonna need it lowered to about 7.2:1
plan sounds good though, mind having a 135 odd bhp mk5 wouldnt be a bad thing either
can get the st170 ones skimmed a little to help bring it down,
and hmm ya it would not but turbo sounds better plan i think
- leighk2010
also, ive just found out today i got the job i recently applied for
so double luck
so double luck
nice one mate which is that?
but on the piston front will either be the vauxhull ones or ill just get forged
- leighk2010
Re: mk5 panther black 2.0 zetec *Now going ZT*
st170 manifold pov sold now so will be able to order the adaptor plate to fit my erst manifold
- leighk2010
oo nice, you make your money back?
will do all been well. but just been looking thought the net and drilling and tapping the head seems to be strong enough as long as done right so mite not get the adaptor plate and can then use money else wear .
- leighk2010
i seen one on ebay a few weeks back going for £30 with no bids
if you can tap th ehead safely, and about 7/10 of the studs or more it should be fine
well all been well as long as all my stuff sells this weekend will be buying a megasquirt ecu to run the zt on
calipers are are there way. And will be drilling and tapping the head some point this week all been well
- leighk2010
your gonna use the high milage engine for the Zetec turbo?
i wouldnt advise that, cant you find a lower milage one?
it will be fine jon its going to be stipped down having crank reground and new bearings etc block bored out to 2.1 so can use so cx20let pistons so bottom will be as good as new when done, plus this is just a stage one engine after this is up and running going to enjoy it for a bit why building up a better engine any way
- leighk2010
sounds bit of a unessesary waste, id just do it now imo
that will be a lot longer the car will be of the road i want it on road some time this year, and the next engine there will be no rush as i want quite a big power/reliable power motor probs say over 400 bhp
this first engine i will be happy for anythink over 200 bhp
- leighk2010
well was going to drill and tap the head but i wanted a way to easily swap the manifold over to another engine if need to be so just orderd this...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_500wt_1156
will probs have to move the rad slightly forward to get clearance but this should not be a problem. as using the adaptor plate adds a extra few cm's to how far the manifold sits from the block.
- leighk2010
This listing () has been removed, or this item is not available.
o Please check that you've entered the correct item number
o Listings that have ended 90 or more days ago will not be available for viewing.
- - Danny Boy -
- Your car: Fiesta Si 2.0
was gonna say myself link is void, but we get the jist lol
If you're interested I have a freshly rebuilt 2.0 black top head, with 16 x brand new valves and stem seals and ported exhaust side. the only problem is it's been stored badly and needs a skim - in view of this I'd sell it based on the value of the valves - call it £70 and its yours.
Excursion :If you're interested I have a freshly rebuilt 2.0 black top head, with 16 x brand new valves and stem seals and ported exhaust side. the only problem is it's been stored badly and needs a skim - in view of this I'd sell it based on the value of the valves - call it £70 and its yours.
were you based mark?
and
here we go guys
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 500wt_1156
- leighk2010
Spec so far:
2.0 blacktop zetec engine
Deposit put down on rebuilt head with new vavles and stem seals,
Exhaust side of head has been ported
cvh to zetec adaptor plate
Erst turbo manifold
Sticker bombed rocker cover
Erst turbo manifold
- leighk2010
well rocker cover is back from been lacquered really hard to get the finish on camera but it looks much better now and all been well will stop the stickers from lifting from the heat
Now waiting on the adaptor plate to turn up and also for pay day so i can pay the rest on the rebuilt head and then that will be posted as well
- leighk2010
- leighk2010
That rocker cover looks brilliant!
- Ratspeed
looks good, the adapter plate is a good quality
it really is very impressed with it considering its a ebay job and only cost me £40 thought i mite be a bit crap but really aint
- leighk2010
