mk5 panther black 2.0 zetec *Now going ZT* : Member's Gallery - Page 5 | Fiesta Forums
Re: mk5 panther black 2.0 zetec
Postby leighk2010 on Wed Nov 24, 2010 4:30 pm
Excursion :
leighk2010 :cheers mate will the bottom mount work the same or will this be needed to be changed as well
All very similar, you won't have to do anything more involved than what you're already doing with the engine mount.
cheers mate im thinking bout going back to trying to use the standard focus mount the bracket bit and modifying it to fit then take a point of the inner wing so it can bolt to there also just a idea i been playing with in my head
whats the best focus box to go for then just so i can get an idea were to mock the mounts up etc for gear box
cheers mark
leighk2010
Postby Excursion on Wed Nov 24, 2010 4:35 pm
leighk2010 :
Excursion :
cheers mark
You may as well fit either an MTX or the ST 6 speed gearbox.
Postby leighk2010 on Wed Nov 24, 2010 4:43 pm
k[/quote]
You may as well fit either an MTX or the ST 6 speed gearbox.[/quote]
been looking at the 6 speedbox but £££ to buy and as im scint atm looking at just a cheap box to get the mount right etc
does the MTX box out of all fords mount the same? or is it focus specific
leighk2010
Postby Excursion on Wed Nov 24, 2010 5:02 pm
Get a 2.0 Zetec Focus gearbox, it will have the right bellhousing pattern for your engine, hydraulic clutch, and similar mounts.
Postby leighk2010 on Wed Nov 24, 2010 5:04 pm
Excursion :Get a 2.0 Zetec Focus gearbox, it will have the right bellhousing pattern for your engine, hydraulic clutch, and similar mounts.
cheers mate once i have the mount in and the shorted shafts etc and all working would there be any think stoping me changing to a st170 box or focus rs mk1 box at a later date?
leighk2010
Postby leighk2010 on Wed Nov 24, 2010 5:19 pm
just found this mark would i be able use the box out of any of them?
MTX75 Gearbox
HD version of the FWD transaxle, originally fitted to the high powered Mk5 Ford Escorts.
Available in 2wd or 4wd versions.
1” x 23 spline input shaft. Fitted in:
Escort Mk5/6 130PS
Escort Mk5/6 RS2000
Mondeo
Focus 1.8D/2.0/RS (not ST170)
Oil capacity: 2wd - 2 litres, 4wd - 2.6 litres (plus 0.3 litres in transfer box).
leighk2010
Postby leighk2010 on Fri Nov 26, 2010 10:54 pm
well bit more of a update
have took the dash out atm to remove the last of the soundproofing from behind the dash and still tidying up the inside of the car atm due to the holes left by everything been riveted to the floor and patching these up with fir tree which are sealed then pushed thought the holes and will be painted over
and also set about removing the the bracket that the battery tray bolts to in the engine bay as the battery is in the boot and thats were it will be staying
and the most like a car this has looked since having it :D still waiting for the v5 to come thought tho been a while now mite have to ring dvla up and check whats going on
leighk2010
Postby jonyb4 on Fri Nov 26, 2010 11:22 pm
:Q
Postby Ratspeed on Fri Nov 26, 2010 11:29 pm
I do love it when a car looks like a car again during a build :)
It makes you realise that all the cut knuckles and swearing will be worth it at the end :Q
Ratspeed
Postby leighk2010 on Fri Nov 26, 2010 11:33 pm
it is a good feeling but shame its only to get the bits out the way :(
leighk2010
Postby jonyb4 on Sat Nov 27, 2010 3:07 am
Ratspeed :I do love it when a car looks like a car again during a build :)
haha i know exsactly what you mean! :lol:
Postby leighk2010 on Sat Nov 27, 2010 8:13 pm
bit more done today and well i hate removing the black sound proofing took hours to just one bit done really could of done with a heat gun :(
before:
after :
then also removed these two patches and also this bit of heat shield of the bulk head as the exhaust it now at the front of the engine
then also patched all the holes up were things have been riveted to the floor i believe this is all of them now so next step is painting the inside of the car :) as all sound proofing has been removed
just to give you a idea how many there was also quite a few more which aint in this pic
also have coved holes in the floor were im guessing he had buckets bolt straight to the floor have used the fir trees to block these up but also instead of just sealing under them have spread sealer over the top as well
also a sneaky pic of the floor points for the roll cage what were already in the shell
leighk2010
Postby jonyb4 on Sat Nov 27, 2010 8:38 pm
bloody hell, you think he doesnt realise all s**t and water can coem up througt the car?
have you still got the cage?
Postby leighk2010 on Sat Nov 27, 2010 9:14 pm
jonyb4 :bloody hell, you think he doesnt realise all s**t and water can coem up througt the car?
i no lol but now its all sorted i hope so still got a few fir trees left out of the 2 bags i brought i say i must of used about 45!
and did not get the cage with the car but its the omp 6 point cage so just a case of buying a new on and bolting it in but am thinking of welding it in and adding a few more bars
leighk2010
Postby jonyb4 on Sat Nov 27, 2010 9:21 pm
ah thats a good plan, add some door bars to it :)
Postby leighk2010 on Sat Nov 27, 2010 9:42 pm
do want door bars :D
leighk2010
Postby leighk2010 on Tue Nov 30, 2010 9:51 pm
not really a update but thinking bout selling the coilovers what are on the car atm to fund getting a st170 gearbox and some other bits good idea or bad idea do we all think?
leighk2010
Postby jonyb4 on Tue Nov 30, 2010 9:57 pm
its alot of work to fit the St box and its cable shift
Postby leighk2010 on Tue Nov 30, 2010 10:15 pm
it is but its also a lot of work getting the sump or gearbox i have modified to fit this blacktop engine and dont seem that much work jsut need to make a mount up
its either st170 box or jsut a normal 2.0 focus box
leighk2010
Postby jonyb4 on Tue Nov 30, 2010 10:34 pm
aye suppose you have a point if your willing to go the extra way really
will be a massive improvement too! :D
Postby leighk2010 on Tue Nov 30, 2010 10:39 pm
it will be really dont no what to do as st170 box would be better but the normal 2.0 would be fine to start with and with the other cash could probs get a exhaust manifold and start on some bike carbs ;)
leighk2010
Postby jonyb4 on Tue Nov 30, 2010 11:15 pm
yea true
surely you can find a firm willing to do some aluminium welding or alloy what ever the sumps made of and alter the bolt patters for you?
im sure that area isnt directly linked to the oil compartment
Postby leighk2010 on Tue Nov 30, 2010 11:20 pm
jonyb4 :yea true
its not just the bolt patten on the sump i idealy want to keep it rear starter as well
have now made my mind up and going for a 2.0 focus mtx75 box :) can always upgrade to a 170 box when the time is needed :P so hopfully should be able to progress with this soon
leighk2010
Postby jonyb4 on Wed Dec 01, 2010 12:17 am
ah good stuff
Postby leighk2010 on Wed Dec 01, 2010 12:20 am
yup just talking to the g.f she going to buy me the box for xmas :D so that's all good slowly getting there now my target for march is still looking good but got a lot left to do yet tho :(
leighk2010
Postby leighk2010 on Sat Dec 04, 2010 10:08 pm
not much of a update but thought id paint the fuel tank before fitting but stuggling to find how the fuel lines are routed
leighk2010
Postby Pumatt on Sun Dec 05, 2010 6:14 am
I'm glad you put pics up of the fuel tank, I'm in process of removing mine :P atleast i know how it looks.
The car looks like its coming along well, looking forward to seing the end result. I've always wanted a fiesta zetec s, one with a tidy engine would make my day. Maybe even a mag feature?
Ford Escort GTi
Ford Puma 1.7 ..... in bits for scrap.
Pumatt
Postby leighk2010 on Sun Dec 05, 2010 12:18 pm
Pumatt :I'm glad you put pics up of the fuel tank, I'm in process of removing mine :P atleast i know how it looks.
i could only ever hope for a mag feature but there is quite a few zs with good engines in a guy over on zsoc has a rs turbo engine in and a few are going for the 2.0 engine now
if i can sell my coilovers and get some standard shocks and springs which mite of arranged with a guy im tempted to buy a st170 engine for it
leighk2010
Postby jonyb4 on Sun Dec 05, 2010 9:10 pm
o you could get the box with it! :D
Postby leighk2010 on Mon Dec 06, 2010 12:06 am
i could do but thinking bout just using the mtx75 box so can keep solid flywheels and cheaper clutch. As the clutch in the 6 speed is part of the dual mass flywheel so have to get a new fly with the clutch making it more £££ were as i don't really need the 6 speed lol
leighk2010
Postby leighk2010 on Mon Dec 06, 2010 9:39 pm
well got hold of a 1.8/2.0 focus plastic type inlet manifold
here it is in place with the zs wiring loom which i have now replaced with the focus loom and changed the end connector to suit so joins the zetec s loom as it should
and a few pics of the loom changed and tided up ready to bolt back on :)
leighk2010
Postby jonyb4 on Tue Dec 07, 2010 12:39 am
that TB looks different to the one on mine :oooh:
Postby leighk2010 on Tue Dec 07, 2010 9:02 am
jonyb4 :that TB looks different to the one on mine :oooh:
its the cougar 2.0 one thats why. just put it on as had it on the other inlet i had lieing around
leighk2010
Postby jonyb4 on Tue Dec 07, 2010 11:39 am
Will it work?
Is it any bigger compared to the silver 2.0 one?
Postby leighk2010 on Tue Dec 07, 2010 4:12 pm
jonyb4 :Will it work?
should work fine all the loom plugs in etc just got to sort the throttle cable out on it :)
not sure how big is the sliver top one and can measurer for you next time up the garage
leighk2010
